12-17-2011 01:49 AM
In 12.4(24)T4, I don't seem to have the SNMP detector in Advanced Security; however, it is present in Advanced IP Services.
Is this a known pre-requisite? I can't seem to find any documentation or guidance from Feature Navigator that this should be the case.
Adv Sec (3845):
(config-applet)#event ?
application Application specific event
cli CLI event
config Configuration policy event
counter Counter event
env Environmental event
interface Interface event
ioswdsysmon IOS WDSysMon event
ipsla IPSLA Event
nf NF Event
none Manually run policy event
oir OIR event
resource Resource event
rf Redundancy Facility event
routing Routing event
rpc Remote Procedure Call event
syslog Syslog event
tag event tag identifier
timer Timer event
track Tracking object event
Adv IP Serv (2811):
cli CLI event
oir OIR event
snmp SNMP event
syslog Syslog event
timer Timer event
Cheers,
Mike
Solved! Go to Solution.
12-18-2011 04:36 PM
This is bug CSCtj01916. The SNMP ED should have been present in all images.
12-18-2011 04:36 PM
12-18-2011 04:39 PM
Thanks, I'll look at the fixed versions and see if they fit on the router.
Cheers,
Mike
