EEM syslog pattern not matching
cwkronk1982
I'm trying to match this after a reload and it never triggers:
event syslog pattern "%CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing."
Can someone provide some insight into why my applet doesn't trigger? I can plainly see this syslog message after reloading, yet the applet never triggers.
May be you can try reboot cron.  ( is the device using AAA any radius - then  authorization bypass need to add to applet)
event manager applet boot-remove-callhome authorization bypass
example on reboot.
event timer cron cron-entry "@reboot"
Action
As per  i know the log was generated part of boot logs, or is this occured after device booted. ?
what EEM Triggers when the Logs pattern matches on live and action it.
if the log already generated before EEM Script loaded, then you need to look for show logging with pattern and match the logs and action it.
BB
11 Replies 11
first think make this Log appear
copy it and then use in with syslog pattern
the log must be exactly the same.
MHM
I've done that. I've also tried several iterations of the log containing portions of the line in case special characters or spaces were causing issues.
add above in your patternet, the log have timestamp and we use .* meaning any thing
 after .* add important part of log
if import part of log not end add  .* in end then add  "
MHM
I've tried:
event syslog pattern ".*%CALL_HOME..."
with the ellipsis replaced by the entirety of the string from logs previously. Doing it again and reloading to see what happens.
balaji.bandi
This was not clear, you getting Log of above message part of the reload ?
how does your EEM Script looks like ?
what happends when you run the EEM Script manually ?
what is the show logging shows ?
Applet triggers when the Live logs appears after switch booted.
BB
event manager applet boot remove-callhome
action 1.0 cli command "configure terminal"
action 2.0 cli command "no service call-home"
action 3.0 cli command "no call-home"
action 4.0 cli command "end"
action 5.0 syslog msg "Call-home removed"
The syslog pattern was copied straight from the logs. I see it every time the switch reloads. I've tried just parts of the message thinking that special character or spaces may have been part of the issue. Event manager statistics policy always shows Triggered = 0 and event manager run remove-callhome returns EEM policy remove-callhome not registered with even none Event Detector.
example on reboot.
Action
BB
This is probably the issue. It runs with the @Reboot. The problem is the timing. The script runs, but then the call-home features are enabled between the script running on reboot. How do I delay it say 60 seconds or so? If I could increase the maxrun to 180 and the delay to 150, that should work. I'm having problems getting the right commands for that.
Hello @cwkronk1982
Consider using alternative triggers for your applet, such as timers or other events, to see if the applet triggers under different conditions.
To introduce a delay before the execution of your EEM applet script, you can use the wait command.
Additionally, if you could adjust the maxrun and delay.
event timer countdown time 60
maxrun 180
delay 150
action 1.0 cli command "enable"
action 2.0 cli command "your_script_command_here"
Best regards
I went back to the @Reboot, added maxrun 200 and inserted an action wait 180. It works now. Thanks for the help.
I changed the event to none and manually triggered it. It ran and event manager statistic policy shows that it triggered once. I was missing the cli command "enable" to make the applet do what I want it too, so I added it and triggered it again. The trigger count went to two and it triggered like it should.
The problem is still that it's not triggering off the syslog pattern line. Could the EEM script not be running that soon after a reboot and missing the trigger?
