EEM/Tcl Script Assistance Part3
Hello Community,
Attached is a script originally posted by Joseph.
When I apply the script I get the following error message:
R2(config)#event manager policy switchstats.tcl
Compile check and registration failed:policy file does not start with event register cmd: file
Tcl policy execute failed: policy file does not start with event register cmd: file
Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy switchstats.tcl: Unknown error 0
I was wondering if someone could take a quick look and let me know what the problem is/
Cheers
Hello Community,
I realised what I was doing wrong, so please ignore the original post.
However, I get the following error on line 22 when I run the script.
uk0149_SW2960_100Cheapside#tclsh switchstats.tcl
extra characters after close-quote
    while executing
"puts $filename "switch, interface, packets input,bytes,no buffer,broadcasts,multicasts,runts,giants,throttles,input errors,CRC,frame,overrun,ignored,w..."
    (file "switchstats.tcl" line 22)
Line 22 is:
puts $filename "switch, interface, packets input,bytes,no buffer,broadcasts,multicasts,runts,giants,throttles,input errors,CRC,frame,overrun,ignored,watchdog,multicast,pause input,input packets with dribble condition detected,packets output,bytes,underruns,output errors,collisions,interface resets,babbles,late collision,deferred,lost carrier,no carrier,PAUSE ,output buffer failures,output buffers swapped out"
Can you help?
Cheers
Community,
Its working fine.
Problem was copying over with tftp
Cheers
