EEM timer trigger stopped working
Ralph Mondegar
Good evening gentlemen,
I've noticed that, on one of my L3 switchs, my EEM scripts that are using timer as a detector simply aren't triggering at all.
I don't know if there is something wrong with the syntax or if it is a bug.
I have tried a simpler version of what I need and isn't working either, which is the following:
event manager applet test
event timer countdown time 30
action 005 syslog msg "test"
action 010 cli command "end"
Nothing goes to logging or terminal output.
I also tried to enable the debug to see if I could catch anything but the output doesn't ring any bell to me. The output is the following:
May 29 23:01:09: fh_send_timer_fd_msg: msg_type=2
May 29 23:01:09: fh_fd_timer_event_create: re=0x660D87C, sid=196
May 29 23:01:09: fh_send_timer_fd_msg: sval=0
May 29 23:01:42: fh_send_timer_fd_msg: msg_type=114
May 29 23:01:42: fh_send_timer_fd_msg: sval=0
May 29 23:02:48: fh_send_timer_fd_msg: msg_type=10
May 29 23:02:48: fh_fd_timer_event_unregister: re=0x65B98D0, sid=195
May 29 23:02:48: fh_send_timer_fd_msg: sval=0
May 29 23:02:48: fh_send_timer_fd_msg: msg_type=6
May 29 23:02:48: fh_fd_timer_event_register: re=0x660D87C, sid=196
May 29 23:02:48: fh_send_timer_fd_msg: msg_type=4
May 29 23:02:48: fh_send_timer_fd_msg: msg_type=32
May 29 23:02:48: fh_fd_timer_event_arm: re=0x660D87C, sid=196
I've searched known bugs under Cisco bugsearch and Google but couldn't find a similar scenario.
Does anyone know what is wrong?
Additional information:
- Switch: WS-C3750X-48T-S
- IOS Version: 12.2(53)SE2
- Embedded Event Manager Version 3.20
- License: ipservices
I haven't seen any issues in 15.0(2)SE relating to timers.  There is a bug in 15.2 code where the timer ED is missing, though.
6 Replies 6
Joe Clarke
This sounds vaguely familiar, but I don't think a bug was ever filed given that the code is fairly old, it was hard to reproduce, and a reboot recovered the issue.  That said, a countdown timer only executes once, so make sure that you're reregistering the policy to get the timer to rearm.
Thanks for answering Joseph.
Yes, I've tested several times and in several switchs. Only that one fails to do anything at all which makes me think it is a bug.
If I change to event none and trigger it manually it works just fine.
Is there a way to check if the policy was registered correctly? Maybe check the remaining timer until it is triggered or even if there is any process that should be running?
show event manager policy registered will show if it's registered properly.  Unfortunately, seeing the remaining timer seconds is not yet implemented (though I have requested it).
I just tested once again and no dice. Is this the output expected?
switch#sh run | begin applet
 event timer countdown time 60
end
switch#sh clock
20:06:26.219 BRT Sat May 30 2015
switch#show event manager policy registered
No.  Class     Type    Event Type          Trap  Time Registered           Secu  Name
1    applet    user    timer countdown     Off   Sat May 30 20:03:02 2015  none  test
 time 60.000
 maxrun 20.000
I should be able to get a window to reboot it next week.
I wonder if the last available ios fixes this.
Thanks again Joseph. I'll give it a try.
Hopefully it works.
