Nexus 9396PX problem prompt [node]
saniago.robledo
Hey there
im pretty new with nexus 9396.
I started the switch and i saw running startup.
after that then ask me for login and i enter admin login. after that i was unable to get swithc mode so now its in node# prompt and i need to configure.
I was able to reload but at reload the info show all like unknow. Help to configure please
AFROJ AHMAD
Hi ,
Looks like you have N9k with ACI .. ?
if yes , try the below steps:
1. To boot into the ACI image, configure the switch to not boot from NXOS using the <no boot nxos> command. After this, save the configuration <copy  running-config  startup-config>
2. Reload the the switch using <reload>
switch(conf)#no boot nxos
switch(conf)#reload
save the config (y)
3. After reload, the switch will boot into the loader prompt. While in loader, you can tell the switch to boot the ACI image using the <boot (ACI image name)> command
4. After bootup of the ACI image .login to the switch using the admin account. There is no password.
5. After booting to the ACI image and logging in,
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/upgrade/guide/b_Cisco_Nexus_9000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6x/b_Cisco_Nexus_9000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6x_chapter_010.html#task_1418077BBEFC4C1DA0624B3B97DBFC8C
also check::
https://supportforums.cisco.com/document/12333246/tip-day-n9k-switch-conversion-process-nxos-standalone-mode-aci-mode
hope it will help
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
