EEM to check Process
Lokesh.Khanna
HI
How can i use EEM to capture 1st 5 process when cpu usage goes above 90 % (5 min avg).
I want to store output in a flash.
I tried generating trap when usage goes above 90% in 5 min and prepared applet based on output which i got.
biut looks like i am doing mistake in regular expression...
Is there any other / better way also to achive same?
THanks
Lokesh
21 Replies 21
many thanks
the applet prints 20 lines, not 5, any idea how to fix it?
I'm not not sure what applet you're trying, but this one will print five lines of processes:
event manager applet dump-procs
event syslog pattern "CPURISINGTHRESHOLD"
action 001 cli command "enable"
action 002 cli command "show proc cpu sorted 5min"
action 003 set lines 0
action 004 foreach line "$_cli_result" "\n"
action 005   if $lines gt 6
action 006     break
action 007   end
action 008   append output $line
action 009   increment lines
action 010 end
action 011 mail to user@company.com from user@company.com server 10.1.1.1 subject "Top five processes" body "$output"
action 012 syslog msg "Top five processes: $output"
Hi Joseph
Could you help me with this problem
- Data
> IOS 12.4(15)T13
- EEM config
CONFIG-SET
event manager applet TEST trap
event syslog pattern "%SYS-5-CONFIG_I:"
action 1.0 cli command "enable"
action 2.0 cli command "sh run"
action 3.0 mail server "192.168.1.146" to "engineer@cisco.com" from "devtest@cisco.com" subject "B25 PBX Alert" body "$_cli_result"
- Debug output
CONFIG-SET
Rack1R1#debug event manager all
All possible Embedded Event Manager debugging has been turned on
Rack1R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Rack1R1(config)#^Z
Rack1R1#
*Mar  1 23:51:34.346: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Mar  1 23:51:34.350: check_eem_cli_policy_handler: command_string=configure terminal
*Mar  1 23:51:34.350: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Mar  1 23:51:35.354: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 23:51:35.362: fh_fd_syslog_event_match: num_matches = 1
*Mar  1 23:51:35.362: fh_fd_data_syslog: num_matches = 1
*Mar  1 23:51:35.366: fh_send_server_sig_hndlr: received a pulse from Syslog Event Detector on node0/0 with fdid: 2
*Mar  1 23:51:35.370: fh_send_syslog_fd_msg: msg_type=62
*Mar  1 23:51:35.370: fh_send_syslog_fd_msg: sval=0
*Mar  1 23:51:35.370: fh_send_server_sig_hndlr: received FH_MSG_EVENT_PUBLISH
*Mar  1 23:51:35.374: fh_schedule_callback: fh_schedule_callback: cc=66B81EDC prev_epc=0; epc=676B600C
*Mar  1 23:51:35.390: fh_schedule_callback: EEM callback policy TEST has been scheduled to run
Rack1R1#
*Mar  1 23:51:35.406: fh_io_msg: received FH_MSG_API_INIT; jobid=14, processid=230, client=4, job name=EEM Callback Thread
*Mar  1 23:51:35.406: fh_server: fh_io_msg: received msg FH_MSG_EVENT_REQINFO from client 4 pclient 1
*Mar  1 23:51:35.422: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_open called.
*Mar  1 23:51:35.430: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Rack1R1>
*Mar  1 23:51:35.430: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : Rack1R1>enable
*Mar  1 23:51:35.430: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Mar  1 23:51:35.430: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Rack1R1#
*Mar  1 23:51:35.510: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Rack1R1#
*Mar  1 23:51:35.510: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : Rack1R1#sh run
*Mar  1 23:51:35.514: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Mar  1 23:51:35.514: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Rack1R1#
*Mar  1 23:51:40.226: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Building configuration...
*Mar  1 23:51:40.226: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Current configuration : 2710 bytes
*Mar  1 23:51:40.226: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : !
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : version 12.4
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : service timestamps debug datetime msec
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : service timestamps log datetime msec
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : no service password-encryption
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : !
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : hostname Rack1R1
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : boot-start-marker
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : boot-end-marker
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : enable password cisco
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : !
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : no aaa new-model
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : memory-size iomem 5
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : ip cef
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : 20+ lines read from cli, debug output truncated
*Mar  1 23:51:40.234: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: _cli_r
*Mar  1 23:51:40.234: %HA_EM-3-FMPD_ERROR: Error executing applet TEST statement 3.0
*Mar  1 23:51:40.238: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_close called.
*Mar  1 23:51:40.242: fh_server: fh_io_msg: received msg FH_MSG_CALLBACK_DONE from client 4 pclient 1
*Mar  1 23:51:40.242: fh_io_msg: EEM callback policy TEST has ended with abnormal exit status of 0xFFFFFFFF
*Mar  1 23:51:40.242: fh_schedule_callback: fh_schedule_callback: cc=66B81EDC prev_epc=676B600C; epc=0
*Mar  1 23:51:40.242: fh_schedule_policy: prev_epc=0x00000000; epc=0x00000000
*Mar  1 23:51:40.250: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 4 pclient 1
*Mar  1 23:51:40.254: fh_io_msg: received FH_MSG_API_CLOSE client=4
- Problem
> How generate more than 20 lines output?
Please start a new thread for your question.
With 12.4(15)T, EEM 2.3 programmatic applets is not possible.  I will need to use Tcl. Please collaborate with me so we can build the correct script.
Need the script to run the following:
5 min cpu value goes about 80 percent, the first page of the "show processor cpu" command output should be emailed it to abc@cisco.com from eem@cisco.com with the subject of "CPU Alert", polling should be every 60 seconds, on any router.
This script should do what you want:
::cisco::eem::event_register_syslog pattern "CPURISINGTHRESHOLD"
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_exec $cli1(fd) "show proc cpu sorted 5min"} _cli_result] {
set lines 0
set _ts "$_cli_result"
while {$_ts != ""} {
    if {[regexp -indices "\n" $_ts _loc] == 0} {
        set line $_ts
        set _ts ""
    } else {
        set _mstart [lindex $_loc 0]
        set _mend [lindex $_loc 1]
        if {$_mstart == 0} {
            set line ""
        } else {
            set line [string range $_ts 0 [expr $_mstart - 1]]
        set _ts [string range $_ts [expr $_mend + 1] end]
    if {$lines > 25} {
        break
    append output $line
    incr lines
set mail_pre "Mailservername: $_email_server\n"
append mail_pre "From: $_email_from\n"
append mail_pre "To: $_email_to\n"
append mail_pre
append mail_pre "Subject: CPU Alert\n\n"
append mail_pre "$output\n\n"
set mail_msg [uplevel #0 [list subst -nobackslashes -nocommands $mail_pre]]
if [catch {smtp_send_email $mail_msg} result] {
# Close open cli before exit.
if [catch {cli_close $cli1(fd) $cli1(tty_id)} result] {
Before registering this policy, you will need to configure the following EEM environment variables in "config t" mode:
event manager environment _email_server SERVER
event manager environment _email_from eem@cisco.com
event manager environment _email_to abc@cisco.com
Where SERVER is your SMTP server IP address.
You will also need to configure your CPU rising threshold accordingly:
process cpu threshold type total rising 80 ...
