Prime LMS - Fault Notification Suppression question
Brad Lawley
I need to find out if Fault Notification and suppression is available or will be available for Prime LMS.  For example, if an upstream device fails then the system only sends out one alert, and not alerts for that device and all downstream devices.  So 1 alert instead of 25 as an example.
Brad
Michel Hegeraat
Level 7
Level 7
There is no RCA and no suppresion. I don't think cisco is working on something like that.
For these features you need to look for emc's smarts or spectrum from c.a. if you need them now.
Cheers,
Michel
