EEM to help with latency spiking issue
kevinhobson2000
I am looking to create an emebedded event manager that checks a ip sla's rtt and when it goes above a certain threshold intitates a trace and stores it in a file on flash.
Can anybody help with this?
Cheers
Kev
Attached is an EEM Tcl policy that should do what you want.  It requires you to set a few environment variables first.
# rtt_collector_id     : IP SLA collector ID to watch.
# rtt_threshold        : Round-trip response time threshold in milliseconds
# rtt_poll_freq        : The number of seconds between each polling interval.
# rtt_dest_ip          : The IP address to which the traceroute will be run.
# rtt_output_file      : File to store the output of the traceroute.
When it runs, a syslog message will be sent to indicate that the traceroute output was saved to the specified output file.
Joe Clarke
By trace, do you mean a traceroute?  What version of IOS are you using?
Hi Joseph,
Yes i mean traceroute.
IOS version is: 12.4(11)T4
Thanks for your help with this.
Cheers
Kev
Joe,
Sorry for taking so long to get back to you.
Thanks for this.
Cheers
Kev
