EEM with redundancy inter-device
dmitry
Level 5
Level 5
I'm putting together a tcl script to read the cisco IOS CA  server certificate requests (pending, granted, etc) in CLI and make the results available via SNMP expression MIB. The two CA servers are configured as a redundant pair with redundancy inter-device. During the script test in EEM the active CA crashed and the standby took over however the EEM /TCL on now active would not run showing
EEM policy  CA.tcl has not been scheduled to run because scheduling is not allowed on standby processor
I verified the redundancy role of the CA to make sure it is active:
Redundancy inter-device state: RF_INTERDEV_STATE_ACT
  Scheme: Standby
      Groupname: CASB Group State: Active
  Peer present: RF_INTERDEV_PEER_COMM
  Security: Not configured
Since then I tried to move the active back to the original active (the one that had the tcl originally run) by rebooting the now acitve, however I was receiving the same message
the event line of the TCL is
::cisco::eem::event_register_timer watchdog name watchdog time $countdown_entry maxrun 240
event manager environment countdown_entry 60
EEM 3.2, IOS 15.1.3T4
6 Replies 6
Joe Clarke
There may be a bug where EEM doesn't support inter-device RF.  Is there a general RF state or command you can show?  EEM Looks to make sure the device is in RF_ACTIVE_FAST to know the policy can be scheduled.  It may be that the RFI state is putting the device in an alternate RF state.
Nope, does not look like there is one that provides RF_ACTIVE_FAST.
The "sh redundancy states" gives
       my state = 13 -ACTIVE
     peer state = 8  -STANDBY HOT
           Mode = Duplex
        Unit ID = 0
     Maintenance Mode = Disabled
    Manual Swact = enabled
Communications = Up
   client count = 11
client_notification_TMR = 30000 milliseconds
           RF debug mask = 0x0
none of the "sh standby .." commands
The "sh redundancy inter-device" on the stand by CA gives:
Redundancy inter-device state: RF_INTERDEV_STATE_STDBY
  Scheme: Standby
      Groupname: CASB Group State: Standby
The interesting thing is that it worked up until the active CA router crashed.
Interesting.  RF_ACTIVE_FAST is state 9, so state 13 should be good (all states greater than or equal to RF_ACTIVE_FAST are considered to be ACTIVE).  Are you getting this error now if you simply try re-registering the EEM policy?
tried several times:
no event manager policy CA.tcl authorization bypass type user
(the debug output of registration is attached)
The scheduler runs the TCL:
003478: Jun 17 17:01:45.402 EDT: fh_fd_timer_process_async
003479: Jun 17 17:01:45.402 EDT: fh_fd_timer_event_expire: re=0x681A48CC
003480: Jun 17 17:01:45.402 EDT: fh_send_server_sig_hndlr: received a pulse from timer on node0/0 with fdid: 19
003481: Jun 17 17:01:45.402 EDT: fh_send_timer_fd_msg: msg_type=64
003482: Jun 17 17:01:45.402 EDT: fh_send_timer_fd_msg: sval=0
003483: Jun 17 17:01:45.402 EDT: fh_send_server_sig_hndlr: received FH_MSG_EVENT_PUBLISH
003484: Jun 17 17:01:45.402 EDT: EEM: server processes multi events: timewin=1, sync_flag=0, ec_index=0, cmp_occ=1
003485: Jun 17 17:01:45.402 EDT: EEM: ctx=7:(7,1,1)
003486: Jun 17 17:01:45.402 EDT: EEM: server processes multi events: corr_res=1, cur_tcnt=1, cmp_tcnt=1
003487: Jun 17 17:01:45.402 EDT: fh_schedule_policy: prev_epc=0x0; epc=0x67E0ED88
003488: Jun 17 17:01:45.402 EDT: EEM policy  CA.tcl has not been scheduled to run because scheduling is not allowed on standby processor
Also tried the manual run (tcl to ::cisco::eem::event_register_none) and got the same message
I think you may have identified a bug with inter-device RF and EEM.  I recommend you open a TAC case so more analysis can be done here.
will do
thanks for looking into this
