Enable SCP in ASR9902
Youn88
I would like to know how to enable SCP in ASR9902 ? The command « ip scp server enable » is unknown.
My software version is 7.6.1
Thank you
balaji.bandi
not tried myself in XR
make sure you enable ssh and then configure SCP Server.
if you do ip ? (you do not see scp, then that function not supported)
BB
I am logged into an XR router, I don't think you can explicitly enable scp, it is on by default, you can send and receive files from the command line:
RP/0/0/CPU0:core-rtr02#scp ?
WORD [[user@][host[:]]][source-filename]
