Enabling Smart Software Licensing
I tried to activate the smart account feature on my nexus 3548XL but I still have an error,
I hade an error when entering the commande :
"license smart enable"
some help please !
as per i know 9.X onwards only smart License, you need to use traditional
Beginning with Cisco NX-OS Release 9.3(3), all Cisco Nexus 3000 and 9000 Series switches (except the Cisco Nexus 3016 and 3064 platform switches) support Smart Software Licensing.
BB
7 Replies 7
Mark Elsen
           - What is the error ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
the switch did not excute the command !.
hello
yes I followed the file you shared but the command " license smart enable " does not run on the switch
can you post show version from device please.
BB
hello,
i use the recommended version  For the 3k
Software
BIOS: version 5.3.1
NXOS: version 7.0(3)I7(9)
BIOS compile time: 06/04/2019
NXOS image file is: bootflash:///nxos.7.0.3.I7.9.bin
NXOS compile time: 8/27/2020 5:00:00 [08/27/2020 08:11:00]
and this is the output of the command
switch(config)# license smart enable
% Invalid command at '^' marker.
switch(config)# exit
switch# license smart enable
switch# conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)# feature licence smart
switch# feature licence smart
regards,
BB
