Cisco 9300-24T SFP-10G-ER not detected
Hi Friends.
          Cisco 9300-24T switch is not detecting the SFP-10G-ER.
IOS Version: 16.12.4
service unsupported-transceiver is enabled
error disable detect cause gbic-invaild is disabled
Even the SFP module is not showing when show interface transceivers.
Suggestion's are most welcome.
post the complete logs when you installing SFP
also check the compatible matrix : (i did not find it supported in Cat 9300 - some data may be wrong?)
https://tmgmatrix.cisco.com/?si=SFP-10G-ER
BB
6 Replies 6
Tagir Temirgaliyev
C9300L-24T-4G—24 1-GE ports
C9300L-24P-4G—24 1-GE ports
C9300L-24T-4X—24 10-GE ports
C9300L-24P-4X—24 10-GE ports
what model?
Switch Ports Model SW Version SW Image Mode
* 1 41 C9300-24T 16.12.4 CAT9K_IOSXE INSTALL
2 41 C9300-24T 16.12.4 CAT9K_IOSXE INSTALL
Uplink module is NM-8X
balaji.bandi
what uplink module you have ? is this a Cisco SFP ? if not try below :
no errdisable detect cause gbic-invalid
BB
Uplink module is Cisco C9300 NM-8X and SFP is Cisco SFP-10G-ER.
I tried below cmd still its not detecting.
pls copy-paste here show ver , show inv
BB
