Encryption Algorithms configuration on switch
noemifabbri
Hi everyone,
One of our customer need to have configured some specific Encryption Algorithms on their switch  WS-C3750X-24 version 15.0(1)SE3. This is his current ip ssh;
sw-core-1#sh ip ssh
SSH Enabled - version 2.0
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 1024 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded):
ssh-rsa ........
and to make it work with the server we need it needs to be like that;
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-110641904
ssh-rsa ....
It is possible? How can i do it?
Noemi
marce1000
 - FYI : https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_ssh/configuration/xe-16/sec-usr-ssh-xe-16-book/sec-secure-shell-algorithm-ccc.html
 M.
noemifabbri
Yes i saw that guide but on this switch there isn't the command ip ssh server that we need to config the ssh algothitm;
sw-ced-3(config)#ip ssh ?
authentication-retries Specify number of authentication retries
break-string break-string
dh Diffie-Hellman
dscp IP DSCP value for SSH traffic
logging Configure logging for SSH
maxstartups Maximum concurrent sessions allowed
port Starting (or only) Port number to listen on
precedence IP Precedence value for SSH traffic
pubkey-chain pubkey-chain
rsa Configure RSA keypair name for SSH
source-interface Specify interface for source address in SSH
connections
stricthostkeycheck Enable SSH Server Authentication
time-out Specify SSH time-out interval
version Specify protocol version to be supported
I think we'll need to upgrade it.
 - You may try upgrading indeed , to disable weak ciphers you can  also try :
                        ip ssh dh min size 2048
  (e.g.)
 M.
basika0911
try and upgrade your plan please
