Energywise on LMS 4.0
Hi guys,
I am currently testing Energywise deployment on LMS 4.0 with the 3 month evaluation. I am running into some issues and have some other queries that i cant find documented or on the forum.
i have gone through the prep and upgraded 2 switches through lms which has been successful. i have created my domain, grouped some test endpoints and have been able to push this config out to the switches.
I created a policy and have tried to push this out to endpoints but the job keeps failing. there is no error detail on the job failure task. i see that it uses protocol "EnergyWise Domain Query" and not netconfig which lms used to push out initial config?  Is there somewhere in the logs i can check what is failing?
I know i can apply this manually on the switch but i want to see if i can get lms to do this as i may be something one of our customers may use.
Anyone had much success with Energywise and LMS? Just wondering if many people have rolled it out.
Gaganjeet Chug
Level 4
Level 4
Hi McPhillips,
Here are the errors found from the log :-
,ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,getFileName,598,java.io.FileNotFoundException: D:\PROGRA~1\CSCOpx\files\rme\jobs\inventory\reports\EOX_PSIRT\PSIRT_EOX_OFFLINE.txt (The system cannot find the file specified)
[ Mon Sep 12  03:33:29 EDT 2011 ],ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,xml_generator,418,Exception occurred
[ Mon Sep 12  03:33:29 EDT 2011 ],ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,xml_generator,420,java.io.FileNotFoundException: D:\PROGRA~1\CSCOpx\files\rme\jobs\inventory\reports\EOX_PSIRT\temp\IOS_112.xml (The system cannot find the file specified)
[ Mon Sep 12  03:33:29 EDT 2011 ],ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,xml_generator,420,java.io.FileNotFoundException: D:\PROGRA~1\CSCOpx\files\rme\jobs\inventory\reports\EOX_PSIRT\temp\IOS_113.xml (The system cannot find the file specified)
Kindly check the casuser persmision on the directory -->
Many Thanks,
Gaganjeet
