EPNM CLI template
bsn1980in
Level 2
Level 2
Hello Experts
We have following template on EPNM and is working well for ASR920, where we are changing SRGB.
segment-routing mpls
no global-block 10000 20000
global-block 20000 30000
But, on few ASR920s, when no global-block 10000 20000 command is executed, router waits and shows a message, "Wait for SR GB Delete Processing to complete before adding/modifying SR GB".  During the wait time third command is sent from EPNM (which is visible in EPNM job logs) but is not executed in the configuration.
Is there a way to update the script so that some time delay can be introduced or the new block configuration is not executed until the prompt on CSG returns to (config-srmpls)# prompt.
I have tried #INTERACTIVE, <timeout>, <pause> keywords in the script but it fails to deploy.
Please suggest!
Bharat
0 Replies 0
