Equivalent to 2500 controller
subarayarsooper
I am using 2500 series wireless lan controller. And I want to add a new latest ap. But this controller is eos. So please suggest me a equivalent controller or Latest Access Point can be added to it.
 The latest AP catalyst 9100 is supported from version 8.10.130.0.  You can use the WLC 3504 on its lastest version.
You can check that on this link:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
3504 is also end of sale. I need current replacement model for 3504.
Then you next option is 9800 or mobility express.
The replacement for 3504 is C9800-L-F-K9 or  C9800-L-C-K9
 https://www.cisco.com/site/us/en/products/networking/wireless/wireless-lan-controllers/index.html
