% Error in authentication
dorrainfra@dorra.com
Frequent Visitor
Frequent Visitor
I have a Cisco WS-C2960X-24PS-L switch and I wrote the command "no enable secret", now I can't enter privileged EXEC mode , when I enter "enable" in user mode the '% Error in authentication ' appears.
how can I enter to global configuration?
sorry for my language
10 Replies 10
Password recovery
You need to enter ROM and add enable password.
Frequent Visitor
Frequent Visitor
if I did that, I will miss the running configuration?
No' we take about password recovery not factory reset
There is no lost of config
Note:- password recovery need reboot if you dont save the config into startup then you will loss it.
There is one solution when I think about your issue'
Do you use aaa for password or local?
Frequent Visitor
Frequent Visitor
i use local authentication, thanks for your effort.
If you access via console and used local user/password without privilege level config for this user can make you access the sw without need enable password.
I think console will give privilege 15 to this user.
Try this way.
Frequent Visitor
Frequent Visitor
I tried to access via console and used my local user /password then it went to user mode >, when write enable, the % Error in authentication appears.
I think you config below
aaa authentication enable default enable
Then remove the enable password
This end to we can not access without enable password.
Sorry you need password recovery.
MHM
if you only entered the command "no enable secret" and not "write" or "copy run start"
then this config has not yet overwritten the startup-config,
so you can just reload the switch to load the old startup-config without any password recovery needed.
Good idea' I test it' if he dont copy run to startup then reboot the SW make him use startup (with enable password) and access to SW.
[email protected] both case you will lose config but @pieterh way is better
