Error on Archive Management
rcrook
Community Member
Error code: CM0039 Error in SQL execution. SQL code 0: Message: JZ0C0: connection is already closed.
David Stanford
What version of RME are you running?
Are you seeing any other error like:
MESSAGE: ASA Error -210: User 'DBA' has
the row in 'DCMA_Archive_Status' locked "
RME version 4.0
Message: JZ006: caught IOException: com.sybase jdbc2.jdbc.SybConnectionDeadException
gianni2006
Visitor
i have the same Error
What can i do?
i can not do anything on RME 4.0.3
also i have this message:
{diskWatcher} - Available space in /var of server mckcw2k1 is less than 20 percent.
What do i need to see to find the problem??
