Error opening flash:/capwap-saved-config (No such file or directory)
abiysm4
I need help to connect  AIR-CAP2702E-E-K9 with WLC.That display a log message
*Mar  1 00:00:34.975: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
%Error opening flash:/capwap-saved-config (No such file or directory)
*Mar  1 00:01:44.999: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:02:34.999: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:02:38.107: %CDP_PD-4-POWER_OK: 15.4 W power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Mar  1 00:02:40.107: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
31 Replies 31
The AP should boot the RCV IOS. This should work. If not, console into the AP and reboot. Post the entire boot-up process. We want to see what the AP is doing.
RCV IOS?
Because there is no more CAPWAP IOS, the AP should boot the IOS found in the folder " ap3g2-rcvk9w8-mx". This is known as the RCV IOS.
How to check the IOS is found in that folder?
Post the complete output to the command "dir".
Directory of flash:/
2 -rwx 269 Jan 1 1970 00:08:24 +00:00 info
3 -rwx 1950 Jun 18 2016 14:50:49 +00:00
atf_override_config_slot0.txt
39 drwx 576 Mar 1 1993 00:04:40 +00:00 ap3g2-rcvk9w8-mx
4 -rwx 56855 Mar 1 1993 00:01:49 +00:00 event.log
5 -rwx 64 Jan 18 2016 14:26:43 +00:00 sensord_CSPRNG0
10 -rwx 314 Mar 1 1993 00:01:44 +00:00 env_vars
79 drwx 0 Mar 1 1993 00:01:04 +00:00 configs
80 -rwx 138665 Jan 10 2018 07:01:59 +00:00 event.r0
81 -rwx 64 Jan 18 2016 14:26:43 +00:00 sensord_CSPRNG1
7 -rwx 0 Mar 1 1993 00:00:35 +00:00 config.txt
83 -rwx 1950 Jun 18 2016 14:50:49 +00:00
atf_override_config_slot1.txt
8 -rwx 1048 Mar 1 1993 00:00:16 +00:00 private-multiple-fs
9 -rwx 120 Mar 29 2018 10:07:04 +00:00
capwap-saved-config-bak
74 -rwx 139571 Jan 10 2018 07:02:12 +00:00 event.r1
40900608 bytes total (34400768 bytes free)
Console into the AP and reboot the AP. I want to see why the AP can't boot the RCV IOS.
IOS Bootloader - Starting system.
flash is writable
Antigua Board
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 21 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 6499840
flashfs[0]: Bytes available: 34658816
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 80:e0:1d:91:e9:30
Ethernet speed is 100 Mb - FULL Duplex
Loading
"flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed,
entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Antigua Board Pre-Pilot
40MB format
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading
"flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...########################
executing...
40MB format
Loading
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed,
entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA3,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 19-Feb-15 10:27 by prod_rel_team
40MB format
Initializing flashfs...
flashfs[2]: 21 files, 3 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 6499840
flashfs[2]: Bytes available: 34400768
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found
at:
export@cisco.com.
cisco AIR-CAP2702E-E-K9 (PowerPC) processor (revision A0) with
376810K/134656K bytes of memory.
Processor board ID FCZ1929Y0EF
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.115.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 80:E0:1D:91:E9:30
Part Number : 73-15823-03
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC1927460C
Top Assembly Part Number : 800-41175-02
Top Assembly Serial Number : FCZ1929Y0EF
Top Revision Number : A0
Product/Model Number : AIR-CAP2702E-E-K9
% ENTERRORLOG: Config load from flash failed. Initialising Cfg
capwap_read_version_info: Info file flash:/ap3g2-k9w8-mx.153-3.JC1/info not
find
*Mar 1 00:00:15.003: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed
state to up
*Mar 1 00:00:15.003: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed
state to up
*Mar 1 00:00:15.143: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:15.187: %LWAPP-3-CLIENTERRORLOG: Config load from flash
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:15.331: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:16.171: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1,
changed state to up
*Mar 1 00:00:20.011: DPAA Initialization Complete
*Mar 1 00:00:20.011: %SYS-3-HARIKARI: Process DPAA INIT top-level routine
exited
*Mar 1 00:00:27.175: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:28.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1,
bridge-group 1 source-learning
% Invalid input detected at '^' marker.
%Default route without gateway, if not a point-to-point interface, may
impact performance
*Mar 1 00:00:33.995: %LWAPP-3-CLIENTERRORLOG: Config load from flash
Ok, leave the AP alone and observe it the AP can get the IP address of the controller.
Post the AP command "sh version".
AP80e0.1d91.e930#sh version
ROM: Bootstrap program is C2700 boot loader
BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m,
RELEASE SOFTWARE (fc2)
AP80e0.1d91.e930 uptime is 2 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
at:
export@cisco.com.
Processor b
*Mar 1 00:02:41.895: %CDP_PD-4-POWER_OK: 15.4 W power -
NON_CISCO-NO_CDP_RECEIVED inline power sourceoard ID FCZ1929Y0EF
Configuration register is 0xF
This is no longer a wireless issue.
The AP has loaded the RCV image. If the AP still can't get an IP address, I'm going to start looking at a network issue.
Are you sure when plugged to a PC, the PC was able to obtain an IP address?
What kind of switch is the AP connected to?
yes,I got an IP
If the Cisco connected to the AP is Cisco, post the complete output to the command "sh interface <BLAH>".
