02-11-2024 06:52 PM
Our network has 2 ISE servers (virtual appliances). A few days earlier I created a Certificate Signing Request (CSR) for server #1 on server #1 without any problems, that certificate has been bound and functions as expected. I have just tried to create a CSR for server #2 on server #1, the CSR was generated but trying to view, export or delete throws an error. The error for exporting is 'The CSR could not be found'. How can I retrieve the generated CSR, is this a known issue or have I missed something?
Just in case this was a one of, the ISE server #1 was restored from backup and another attempt was made to create the CSR with the same result. Rebooting the servers also did not help. Thanks in advance for any assistance.
02-11-2024 07:40 PM
I found the bug below. The 'solution' is to contact TAC for a manual database cleanup...
ISE: CSR requests are stuck in DB, invisible in GUI
CSCuh91639
CSCuh91639
Customer Visible
Notifications
Save Bug
Open Support Case
Description
Symptom:
ISE may not allow to generate a CSR reporting:
A Certificate Signing Request with the subject 'CN=....' already exists.
ISE GUI will not show any information about a existing CSR.
Conditions:
ISE 1.1.3
Workaround:
Contact TAC to perform manual DB cleanup.
Further Problem Description:
This a problem on DB level. Where a CSR will not be visible in GUI but still stuck in CLI.
02-11-2024 10:07 PM
ISE GUI fails to display CSR requests stuck in DB. Workaround: Contact TAC for manual database cleanup
02-11-2024 10:07 PM
Error retrieving CSR on server #1 after generating for server #2. Restored from backup, the issue persists. Seeking resolution.
