EVE-NG MANAGEMENT CLOUD
Jesutofunmi O
Hi Guys. I have installed eve-ng on Hyper-V on Windows 11. I am trying to run multiple routers and FortiGate devices but have not been able to access the devices from my PC. I am using a bridged-adapter. My home network issues an IP address to my eve-ng vm and that works just fine. However, when I bring up my routers and FortiGate devices and enable their interfaces for DHCP, they do not receive IPs while connected to the eve-ng management cloud. I also cannot ping the host PC from the FortiGates and vice versa.
This is my first time using Hyper-v for eve-ng (new machine), so I am wondering if there is something else I need to do in other to be able to access these devices from my PC since they're supposedly on the same network. I have tried assigning static IP's to the connected router interfaces and even configure static route (unnecessarily) but still, no pings, ssh or telnet. Nothing works. Any suggestions please?
PS: When I assign a static IP to the routers/FortiGates device, they are able to ping the eve-ng management IP address (the DHCP address received by eve-ng vm via the bridged-adapter).
marce1000
    - You may go here for that  : https://www.eve-ng.net/forum/
 M.
marce1000
 M.
azmi-abas-989
Im having the same issue, any solutions found ?
@azmi-abas-989, the problem with mine was WiFi. I switched to LAN (RJ45) and that fixed it.
