Event Manager question. Monitoring DNS entry.
Hello everybody,
I  want to use Cisco Embedded Event Manager in a router for monitoring a  DNS entry that normally resolves 1.1.1.1 but if it changes to 2.2.2.2 the  router has to change some access list automatically in order to permit different  routes.
I  know how to configure de "action" sentences for change the ACLs but I  dont know how to configure a track or a SLA in order to check the DNS  entry and react if it changes.
Someone knows how to do that?
event manager applet ChangeRoutesWhenDNSEntryChanges
event track 21 state ??????????????????????????????????????????????????<----------
action 1.0 cli command "enable"
action 2.0 cli command "configure terminal"
action 3.0 cli command "ip access...
Thank you in advance!!
Marcos.
Indeed, I just provided the above example to demonstrate how we can force a DNS lookup and parse the IP address...
I was actually thinking about using the IP SLA DNS probe, but I could not find a way to get the IP address from the results... It just shows the response time.
In order to make the script work, we would most likely need to use some timer to trigger it periodically.
This is an adaptation of my previous example to actually accomplish a periodic check:
event manager applet CHECK-DNS
event timer watchdog time 60
action 1.0 cli command "ena"
action 1.1 cli command "ping host1 repeat 1 timeout 0"
action 2.0 regexp "ICMP Echos to (.*), timeout is 0 seconds:" "$_cli_result" _match _ip
action 3.0 if $_ip ne 1.1.1.1
action 4.0  syslog msg "host1 is now $_ip"
action 5.0 end
If you want to do something as a reaction to detecting the change, that would have to go into the "4.0" block (you can use 4.1, 4.2 etc)
Another thing to consider is that this script would run every minute, so as long as the DNS query resolves to anything but 1.1.1.1 we would re-apply the config changes, which is not that good...
A way to solve this can be seen in the next example:
event manager applet HOST1-NOT-1.1.1.1
action 2.1 track read 100
action 3.0 if $_ip eq 1.1.1.1
action 4.0  if $_track_state eq down
action 4.1   track set 100 state up
action 4.2   syslog msg "host1 is now 1.1.1.1 again"
action 4.9  end
action 5.0 else
action 6.1  if $_track_state eq up
action 6.2   track set 100 state down
action 6.3   syslog msg "host1 is not 1.1.1.1, new ip is $_ip"
action 6.9  end
action 7.0 end
Basically we are using a stub tracking object to maintain state. Track object 100 would be up if we know host1=1.1.1.1, but if we detect it is something else we change it to down. Only after we detect that host1=1.1.1.1 again we change the track object back to up, which would enabled detecting another change...
Any actions you want to take should go into section "6" and any clean up (when host1=1.1.1.1 again) has to go into section "4".
It is possible to make this detect any change and not just have a static 1.1.1.1 value by assigning the newly detected value to a variable and basically look for a change... Not sure what is your requirement.
The output below shows how this works...
Router#show run | inc ip host
ip host host1 1.1.1.1
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#ip hos
Router(config)#ip host host1 2.2.2.2
Router(config)#^Z
Router#
*Nov  9 18:23:18.009: %TRACKING-5-STATE: 100 stub   Up->Down
*Nov  9 18:23:18.021: %HA_EM-6-LOG: HOST1-NOT-1.1.1.1: host1 is not 1.1.1.1, new ip is 2.2.2.2
Router#
*Nov  9 18:23:18.065: %SYS-5-CONFIG_I: Configured from console by console
Router#
Router#
Router#conf t
Router(config)#ip host host1 1.1.1.1
Router(config)#^Z
Router#
*Nov  9 18:23:42.805: %SYS-5-CONFIG_I: Configured from console by console
Router#
*Nov  9 18:24:18.025: %TRACKING-5-STATE: 100 stub   Down->Up
Router#
*Nov  9 18:24:18.033: %HA_EM-6-LOG: HOST1-NOT-1.1.1.1: host1 is now 1.1.1.1 again
8 Replies 8
avayner
Marcos,
We could run a periodic ping using the hostname. This would trigger a DNS lookup, and we can parse the resolved IP...
What IOS/EEM version is this running on?
Arie
I also have some Tcl code here in CSC (host.tcl) that will do A record DNS lookups.  However, for simplicity, I would agree that ping would be a good option.  You'd have to go with a timer ED, likely.  I don't see how a track ED would work here.
Thanks you guys for your answers.
Arie, the versions are:
#sh event manager version
Embedded Event Manager Version 3.10
Component Versions:
eem: (v310_throttle)4.1.23
eem-gold: (v310_throttle)1.0.7
eem-call-home: (v310_throttle)1.0.6
Event Detectors:
Name                Version   Node        Type
application         01.00     node0/0     RP
syslog              01.00     node0/0     RP
rf                  01.00     node0/0     RP
track               01.00     node0/0     RP
resource            01.00     node0/0     RP
routing             02.00     node0/0     RP
cli                 01.00     node0/0     RP
counter             01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
none                01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
timer               01.00     node0/0     RP
snmp-object         01.00     node0/0     RP
test                01.00     node0/0     RP
config              01.00     node0/0     RP
env                 01.00     node0/0     RP
gold                01.00     node0/0     RP
rpc                 01.00     node0/0     RP
#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M7, RELEASE SOFTWARE (fc2)
Which kind of commands I will need to introduce?
Do I need to declare a SLA and create a track? something like:
ip sla 1
icmp-echo test.xxxx.com
track 1 ip sla 1 ???
I'm CCNP but I have not previus experience with eem so I'm not sure to understand how to do what you said.
Thank you so much in advance, you help is very appreciated!!
Kind regards,
Marcos.
I just hacked this example using EEM 3.1. Hope it gives you a head start:
event manager applet RESOLVE
event none
action 1.0 cli command "ping host1"
action 2.0 regexp "ICMP Echos to (.*), timeout is 2 seconds:" "$_cli_result" _match _ip
action 3.0 puts "IP Address is $_ip"
Arie
Ok Arie, I will try it as soon as I understand exactly what it does.
Thank you so much.
Marcos,
Let me add some info on the examples I shared earlier:
event none
action 1.0 cli command "ping host1 repeat 1 timeout 0"
This script can be executed by using this command:
Router#event manager run RESOLVE
IP Address is 1.1.1.1
(I configured "ip host host1 1.1.1.1" on my router so it would resolve)
(I added "repeat 1 timeout 0" to the ping command so if the destination is not responding, we don't have a delay)
The script executes a ping to "host1", which forces the router to do a DNS lookup for host1 and initiate a ping request to the IP address.
The ping command's output looks like this:
"Sending 1, 100-byte ICMP Echos to 1.1.1.1, timeout is 0 seconds:"
This string is populated into the $_cli_result system variable.
The next line (2.0) does a regular expression match on the output, capturing the IP address. Note the (.*) part of the regexp string, which captures the IP address. It is then pushed into the _ip variable (the _match variable gets the whole match of the regexp, and we do not care about it)
So at this point $_ip has the IP address...
In your use case, you would have to compare it to your reference IP (using an "if" action), and perform any relevant actions if you detect a change.
Arie
Hi Arie,
thank you again. I understand the code know, but I think it will not be executed automatically because I have to introduce the command event manager run RESOLVE. The point is that the device has to realise the IP of the DNS entry for host1 has been changed and it will execute the actions that will change the access-lists.
In other devices (.in which we can monitor an IP and not a host name DNS entry) we use this code:
ip sla 1
icmp-echo 10.10.10.10
timeout 1000
threshold 1000
frequency 10
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
delay down 30
event manager applet SCRIPT
event track 1 state down
action 1.1 cli command "configure terminal"
action 2.0 cli command "ip dhcp pool POOL1"
action 2.1 cli command "dns-server 10.10.10.11"
action 2.2 cli command "exit"
action 3.0 cli command "ip access-list extended ACCESSLIST1"
action 3.1 cli command "no 10 deny ip any 10.10.0.0 0.0.255.255"
action 3.2 cli command "10 deny ip any 10.10.0.0 0.0.255.255"
action 4.0 cli command "end"
action 4.1 cli command "wr mem"
So it changes automatically when the IP stops answer to the ping. (Then there is another similar code which do the opposite)
How I could automate your code?
Thanx in advance!
action 5.0 end
action 4.9  end
action 5.0 else
action 6.9  end
action 7.0 end
Router#conf t
Router(config)#^Z
Router#
Router#
Router#
Router#
Router#conf t
Router(config)#^Z
Router#
Router#
Router#
