Execute commands in multiple Cisco devices simultaneously
walter.perera
Hi all:
We have a big network and every time we need to execute commands in switches and routers, it takes a lot going one by one to do it. Is there any way, ie using special software, or Linux, scripts, whatever that can be used to execute same commands in all devices at the same time?
Thanks in advance
W.
Martin Ermel
in CiscoWorks LMS there is the  RME NetConfig task which can do this for you. You can download an eval copy of LMS here (90 day eval for 100 devices)
http://www.cisco.com/go/nmsevals or
https://cisco.mediuscorp.com/market/networkers/listSubCat.se.work?TRGT=8&/nxt/rcrs/=1126
to get the solaris version
but there is also the the "Cisco Enhanced Device Interface" which perhaps could be a solituon for you:
http://www.cisco.com/en/US/products/ps6456/tsd_products_support_series_home.html
not forget to mention the Kiwi Cat Tools:
http://www.kiwisyslog.com/kiwi-cattools-overview/
anastarsha
You can easily do with with parallel SSH on Linux. See the link for more details:
http://anastarsha.com/use-parallel-ssh-to-run-commands-on-multiple-devices-at-the-same-time/
