expect regexp example
fractal90
Level 6
Level 6
Hi, does anyone have an example of how to select some data in expect via regexp and write it to a variable so that it can be used later?
show run | inc hostname
hostname test-gw
sh ip int br | i Vlan9
Vlan9                    192.168.100.200  YES NVRAM  up                    up
i wrote code like this
expect -exact "#" {send -- "show run | inc hostname\n"}
regexp {hostname ([\_A-Za-z0-9]+)} $expect_out(buffer) matched name
expect -exact "#" {puts "Hostname: $name"}
expect -exact "#" {send -- "sh ip int br | i Vlan9\r"}
regexp {([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)} $expect_out(buffer) matched ip_src
expect -exact "#" {send -- "ping $ip_src"}
but he doesn't want to work
14 Replies 14
fractal90
Level 6
Level 6
it does not work too
regexp {!?gw} $expect_out(buffer) matched name
expect -exact "#" {puts "name: $name"}
This works.
#!/usr/bin/expect
set timeout -1
spawn $env(SHELL)
match_max 100000
send -- "ssh  [email protected]\r"
expect -exact "Password: "
send -- "admin\r"
expect -exact "#"
send -- "show run | inc hostname\r"
set myhost [string trim $expect_out(buffer)]
puts "My hostname is $myhost"
# Run script [dafrey@CrashCart biz]$ ./exprouter.tcl spawn /bin/bash ssh [email protected] [dafrey@CrashCart biz]$ ssh [email protected] Password: lab-csr7#My hostname is lab-csr7# [dafrey@CrashCart biz]$
hi, yes, this is how I tried it, but here's what to do if we only need "csr7"
OK.  The match takes place after the dash.
#!/usr/bin/expect
set timeout -1
spawn $env(SHELL)
match_max 100000
send -- "admin\r"
expect -exact "#"
regexp {\-([\_A-Za-z0-9]+)} $myhost match name
puts "My hostname is $name"
hm, I’m starting to understand, but if there is no task to cut the string?
let's say we execute "sh ip int br | inc vla10"
and in it regexp "\ d + \. \ d + \. \ d + \. \ d +" will work? I haven’t gotten to the pc yet to test it myself
Find out what the output looks like without any regexp, then add in regexp and test again.   The easiest way to do this is with the interactive tcl shell in IOS.   tcl and expect are very similar.
C3750X-G#tclsh
C3750X-G(tcl)#set result [exec show ip int brief | inc Vlan11]
Vlan11                 192.168.223.1   YES NVRAM  up                    up
C3750X-G(tcl)#regexp {(\d+.\d+.\d+.\d+)} $result match v11
C3750X-G(tcl)#puts $v11
192.168.223.1
something is wrong, in tcl I checked it works there, in eem, it works, but expect resists
it work
expect -exact "#"
send -- "sh run | i hostname\r"
set name $expect_out(buffer)
regexp {([\_A-Za-z0-9]+)} $name match hostname
puts "$hostname"
test-gw#show run | inc hostname
hostname test-gw
 ./ssh 192.168.18.200
spawn ssh -o StrictHostKeyChecking=no [email protected]
Password:
test-gw#test
it doesn't work.....
expect -exact "#"
set src $expect_out(buffer)
regexp {([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)} $src match ipsrc
puts "ADDRESS: $ipsrc"
test-gw#sh ip int br | i Vlan9
Vlan9 192.168.18.200 YES NVRAM up up
Password:
test-gw#can't read "ipsrc": no such variable
    while executing
"puts "ADDRESS: $ipsrc""
    (file "./ssh" line 26)
Looks like your device is not doing regexp to make variable ipsrp because src variable is not present.   Most likely it is not running the "show ip int brief | inc vlanxx" command.   Some tweaks below.
expect -exact "#"
send -- "show ip int brief | inc Vlan11 \r"
expect -exact "#"
set v11 $expect_out(buffer)
regexp {([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)} $v11 match srcip
puts "  ADDRESS: $srcip"
[root@CrashCart  biz]# ./exprouter.tcl
spawn /bin/bash
[root@CrashCart  biz]# ssh  [email protected]
Password:
C3750X-G#show ip int brief | inc Vlan11
C3750X-G#  ADDRESS: 192.168.223.1
very strange, because I took the commands directly from the eem script on the same router, I'm now trying to make an out-of-the-box check of the router
Apparently after executing the command "show ip int br | inc Vlan9" there is a delay, the variable has not yet been created, and regexp is trying to perform the next action, added after "show ip int br | inc Vlan9" a string to expect the character "expect -exact" # "" and it worked
expect -exact "#"
expect -exact "#"
regexp {(\d+.\d+.\d+.\d+)} $src match ipsrc
Password:
test-gw#ADDRESS: 192.168.18.200
fractal90
Level 6
Level 6
the question arose, if we can do such checks in one script, ping / tracert, port status, how to separate them with brackets, and how to use timeout more correctly?
expect -exact "#"
send -- "sh int des | i main | Main\r"
expect -exact "#"
set description $expect_out(buffer)
regexp {(Gi0\/1\/0)|(Fa0\/0\/0)|(Fa0)|(Gi0)} $description match interface
expect -exact "#"
send -- "sh int $interface\r"
#expect -exact "#"
#send -- "sh ip int br | i Vlan9 \r"
#expect -exact "#"
#set src $expect_out(buffer)
#regexp {(\d+.\d+.\d+.\d+)} $src match ipsrc
#expect -exact "#"
#send -- "ping $ipsrc\r"
fractal90
Level 6
Level 6
Noticed an oddity, I checked in tclsh:
test-gw#tclsh
test-gw(tcl)#set result [exec sh ip cef | i 0.0.0.0.*Vlan9]
0.0.0.0/0            192.168.100.2          Vlan9
test-gw(tcl)#regexp {([1-9]+.[0-9]+.[0-9]+.[0-9]+)} $result match int_back
test-gw(tcl)#puts $int_back
192.168.100.2
try in expect
expect "#"
send -- "sh ip cef | i 0.0.0.0.*Vlan9 \r"
expect "#"
set dst $expect_out(buffer)
regexp {([1-9]+.[0-9]+.[0-9]+.[0-9]+)} $dst ipshow
puts "router is dst ip $ipshow"
but, it does not work, it gives an error
 expect -d ssh 192.168.18.200
expect version 5.45.4
argv[0] = expect  argv[1] = -d  argv[2] = ssh  argv[3] = 192.168.18.200
set argc 1
set argv0 "ssh"
set argv "192.168.18.200"
executing commands from command file ssh
/***  DATE is Thu Mar 18 10:40:20 MSK 2021 ***/
parent: waiting for sync byte
parent: telling child to go ahead
parent: now unsynchronized from child
spawn: returns {29533}
expect: does "" (spawn_id exp6) match glob pattern "*assword:"? no
Password:
expect: does "\rPassword: " (spawn_id exp6) match glob pattern "*assword:"? yes
expect: set expect_out(0,string) "\rPassword:"
expect: set expect_out(spawn_id) "exp6"
expect: set expect_out(buffer) "\rPassword:"
send: sending "123456\r" to { exp6 }
expect: does " " (spawn_id exp6) match glob pattern "#"? no
expect: does " \r\n" (spawn_id exp6) match glob pattern "#"? no
test-gw#
expect: does " \r\n\r\ntest-gw#" (spawn_id exp6) match glob pattern "#"? yes
expect: set expect_out(0,string) "#"
expect: set expect_out(buffer) " \r\n\r\ntest-gw#"
send: sending "sh ip cef | i 0.0.0.0.*Vlan9 \r" to { exp6 }
expect: does "" (spawn_id exp6) match glob pattern "#"? no
s
expect: does "s" (spawn_id exp6) match glob pattern "#"? no
h
expect: does "sh" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh " (spawn_id exp6) match glob pattern "#"? no
i
expect: does "sh i" (spawn_id exp6) match glob pattern "#"? no
p
expect: does "sh ip" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip " (spawn_id exp6) match glob pattern "#"? no
c
expect: does "sh ip c" (spawn_id exp6) match glob pattern "#"? no
e
expect: does "sh ip ce" (spawn_id exp6) match glob pattern "#"? no
f
expect: does "sh ip cef" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef " (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef |" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | " (spawn_id exp6) match glob pattern "#"? no
i
expect: does "sh ip cef | i" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i " (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i 0" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i 0." (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i 0.0" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i 0.0." (spawn_id exp6) match glob pattern "#"? no
0.
expect: does "sh ip cef | i 0.0.0." (spawn_id exp6) match glob pattern "#"? no
0.
expect: does "sh ip cef | i 0.0.0.0." (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i 0.0.0.0.*" (spawn_id exp6) match glob pattern "#"? no
V
expect: does "sh ip cef | i 0.0.0.0.*V" (spawn_id exp6) match glob pattern "#"? no
l
expect: does "sh ip cef | i 0.0.0.0.*Vl" (spawn_id exp6) match glob pattern "#"? no
a
expect: does "sh ip cef | i 0.0.0.0.*Vla" (spawn_id exp6) match glob pattern "#"? no
n
expect: does "sh ip cef | i 0.0.0.0.*Vlan" (spawn_id exp6) match glob pattern "#"? no
9
expect: does "sh ip cef | i 0.0.0.0.*Vlan9 \r\n" (spawn_id exp6) match glob pattern "#"? no
test-gw#
expect: does "sh ip cef | i 0.0.0.0.*Vlan9 \r\ntest-gw#" (spawn_id exp6) match glob pattern "#"? yes
expect: set expect_out(buffer) "sh ip cef | i 0.0.0.0.*Vlan9 \r\ntest-gw#"
can't read "ipshow": no such variable
    while executing
"puts "router is dst ip $ipshow""
    (file "ssh" line 60)
but if I change the regex like this:
expect "#"
expect "#"
regexp {([0-9]+.[0-9]+.[0-9]+.[0-9]+)} $dst ipshow
then everything works, but only 0.0.0.0 gets into the selection
set argc 1
set argv0 "ssh"
/***  DATE is Thu Mar 18 10:49:58 MSK 2021 ***/
spawn: returns {1970}
Password:
test-gw#
expect: does " \r\ntest-gw#" (spawn_id exp6) match glob pattern "#"? yes
expect: set expect_out(buffer) " \r\ntest-gw#"
s
h
 i
p
c
e
f
i
expect: does "sh ip cef | i 0.0.0" (spawn_id exp6) match glob pattern "#"? no
expect: does "sh ip cef | i 0.0.0.0" (spawn_id exp6) match glob pattern "#"? no
V
l
a
n
9
expect: does "sh ip cef | i 0.0.0.0.*Vlan9 " (spawn_id exp6) match glob pattern "#"? no
test-gw#
router is dst ip 0.0.0.0
fractal90
Level 6
Level 6
it is not clear why, but changing the command
"sh ip cef | i 0.0.0.0. * Vlan9 \ r"
to
"sh ip cef | i 0.0.0.0/0 \ r" and it all worked
expect "#"
send -- "sh ip cef | i 0.0.0.0/0 \r"
expect "#"
fractal90
Level 6
Level 6
Why with this code, the login to the device is successful only on the second attempt?
spawn ssh -o StrictHostKeyChecking=no $user@$host
sleep 3
send "$pass\n"
*Mar 19 10:39:22.580: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: test] [Source: 172.18.7.22] [localport: 22] [Reason: Login Authentication Failed] at 10:39:22 UTC Fri Mar 19 2021
*Mar 19 10:39:22.584: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: test] [Source: 172.18.7.22] [localport: 22] at 10:39:22 UTC Fri Mar 19 2021
/***  DATE is Fri Mar 19 13:38:52 MSK 2021 ***/
spawn: returns {590}
expect: does "" (spawn_id exp6) match exact string "Password: "? no
expect: does "\rPassword: " (spawn_id exp6) match exact string "Password: "? yes
expect: set expect_out(0,string) "Password: "
expect: set expect_out(buffer) "\rPassword: "
send: sending "123456\n" to { exp6 }
expect: does "\r\n" (spawn_id exp6) match glob pattern "#"? no
expect: does "\r\n\r\ntest-gw#" (spawn_id exp6) match glob pattern "#"? yes
expect: set expect_out(buffer) "\r\n\r\ntest-gw#"
