Export ACS Network Device Group
MBrooksAirIT
Hello All- Is there any way to export a Network Device Group from ACS v4.2?
Thanx
-michael
Robert Pavone
Michael,
Yes you can export the NDGs, but not through the CSUtil.  You'll need to use the RDBMS Synchronization utility through the GUI to export the NDG (See the READ_NAS option).
Wow.
I have read some convoluted guides before, but this one is the crown jewel: http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/SCAdv.html#wp756877
Gotta be a straightforward way to extract the NDG. Can you tell me the commands? (Or at this point I am not sure if I need to use the GUI...). The server is a Windows 2003 R2 box, no other ACSs, and it looks like I would be able to use the CLI using "action code" 225.
Thanx
I know this is painful.  I'm not sure why the developers did not put this export capability in the CSUtil.exe executable.  That's where this functionality should reside IMHO.
Sorry it is is not an easier solution.
Rob
MBrooksAirIT
No takers eh?
Robert, I will give you a couple stars for the attempt at least.
Thanx
