Export capture buffer
BobGreer65666
Hi there,
Thanks for reading.
I have a c9200L running 16.12.4.  I'm not finding the FILE flag as part of a packet capture.  The EXPORT command assumes that I've written to a file.  I thought there was a way to copy the buffer into a local file?
Thanks again!
Bob
marce1000
 - Check steps from here :
            https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-10/configuration_guide/nmgmt/b_1610_nmgmt_9200_cg/configuring_packet_capture.html#id_136279
 M.
Seb Rupik
Hi there,
Are you using the command:
monitor capture buffer <buffer_name> export <destination>
... the destination can be a local or remote filesystem. eg:
monitor capture buffer my_capture export flash:my_cap.pcap
cheers,
Seb.
marce1000
 M.
Hi Marce1000,
Thanks for the URL.  I found the command i needed there:
monitor capture mycap export tftp://x.x.x.x/filename.pcap
 Buffer doesn't need a local file; just name it in the destination.
Thanks again!
