Cisco 1841 limit bandwidth
chirath822
Dear All
I m looking to Restrict up/down bandwidth to 128 Kb on my router. the point is to save data quota of my broadband connection.
whoever browse the internet they will have only 128Kbps and the speed checker will show 0.1 Mbps
and 64 for some other users
can someone help me to do this
Thank you
chirath
marce1000
 - Check if these threads can be helpful :
         https://community.cisco.com/t5/routing/1841-router-limit-bandwidth-with-priority-for-voice/td-p/1707754
         https://community.cisco.com/t5/routing/limiting-bandwidth-by-using-qos-on-cisco-1841-is-it-possible/td-p/1565600
  M.
balaji.bandi
At this stage we are not sure - how much bandwidth you have, are you looking to restrict user for 128Kbps
that means if you have 10MB/128kbs = number of users ?
if you looking to allow maximum 128kbps if available to share among the bandwidth equavally based on the availability.
also post what configuration  you have at the moment.
BB
