Exporting Netflow on Cisco 4331
utawakevou
Level 4
Level 4
I need help with the above. Im using the management port on its own VRF. Can ping the netflow analyzer server from the router but can see an anything at all on the NFA server. Here is my configuration and probably something I'm missing ?:
flow record NFArecord
match ipv4 source address
match ipv4 destination address
match ipv4 protocol
match transport source-port
match transport destination-port
match ipv4 tos
match interface input
collect interface output
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
collect application name
flow exporter NFA
destination 192.168.0.5 vrf Mgmt-intf
source GigabitEthernet0
transport udp 9996
template data timeout 60
option application-table timeout 60
option application-attributes timeout 60
flow monitor NFAmonitor
exporter NFA
cache timeout inactive 60
cache timeout active 60
record NFArecord
interface GigabitEthernet0/0/3
ip flow monitor NFAmonitor input
ip flow monitor NFAmonitor output
I can ping the server from the router using that VRF
ping vrf Mgmt-intf 192.168.0.5
Sending 5, 100-byte ICMP Echos to 192.168.0.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Any help will be really apprecaited
balaji.bandi
is this both the interface part of VRF - interface GigabitEthernet0/0/3 and GigabitEthernet0
try to change version 5 to 9 and test. "ip flow export version 9"
please post below output :
show version
show flow monitor NFAmonitor cache
BB
Only interface GigabitEthernet0 is in the management VFR. interface GigabitEthernet0/0/3 netlow is the flow I want to be exported to the NFA server.
see attach for the result of show version and the sample of netflow table
I have never tried exporting to VRF with a normal Routing table using Netflow.
I am sure VRF and Default routing table need to exchange each other information so the information will be replicated to VRF and GRT
try the below thread -  adding some information VRF aware.
match routing vrf input
 match routing vrf output
https://community.cisco.com/t5/routing/asr1000-flow-export-to-vrf-mgmt-intf/td-p/1568327
https://community.cisco.com/t5/switching/netflow-vrf-export/td-p/1339418
EDIT :
i was searching my document in one note :
found this URL may be helpful :
https://wannabelab.blogspot.com/2016/08/configuring-flexible-netflow-fnf-using.html?m=1
BB
Thank you. I've tried that to no avail. I don't understand why it doesn't work as I've got RADIUS, syslog working via the management VRF
