extended ping and traceroute
daniel4579329
hi
from wich devices i can do extended ping and extended traceroute
balaji.bandi
You can do any IOS device
ping Enter (without IP will give you more option)
BB
balaji.bandi
BB
thanks for the reply
what about ping ip and ping with hostname i can do them from every ios device?
ping with hostname required DNS resolution, if you configured name server to resolve the hostname.
technically it should work for all the IOS as per my usage.
BB
Martin L
I know extended ping and traceroute from routers; not sure if extended traceroute is supported on all switches; some older version may not let you do extended traceroute/ping
Regards, ML
**Please Rate All Helpful Responses **
