failed status when trying to sync device configuration
russnash
all credintials seem to be correct.
5 Replies 5
Thomas Masters
It appears the device package for this device may need updating in the application.
LMS 3.x CS -> Software Center -> Device Update
LMS 4.x Admin -> System -> Software Center -> Device Update
Update devices for RME.
If its a new device you can check for supportability in this link under  "release notes and general"
http://www.cisco.com/en/US/products/ps11200/index.html
Tom
looks like there are 45 or so for RME. will install and see what happens.
go the following error message when trying to run one of the jobs.
You will have to delete the ...\CSCOpx\PSU.Lock file and then attempt the update again.
cannot find this file to be able to delete. which directory does it reside?
