Failed to upload APC UPS MIB file to Prime Infrastructure 3
superego
Got an error when importing powernet426.mib to Cisco Prime 3.1.  Trying to add the mib to monitor UPS.
mib can be found here:
https://www.schneider-electric.com/en/download/document/powernet426/
Error: Failed to load MIB powernet426.mib. Please refer /opt/CSCOlumos/logs/miblibrary.log for more details.
Here's the miblibrary.log:
2018-06-07 09:10:13,730 [http-nio-443-exec-32] ERROR MibLibraryMibbleImpl - Error parsing file file:/opt/CSCOlumos/conf/da/mibs/tmp/1528377013360/powernet426
2018-06-07 09:10:13,730 [http-nio-443-exec-32] ERROR MibLibraryMibbleImpl - Error: in <unknown file>:
undefined symbol 'Integer32'
undefined symbol 'Unsigned32'
6 Replies 6
iportuga
Could you share the MIB file?
PowerNet MIB v.4.2.6
Can be downloaded from:
I'm unable to upload the MIB  here as it is not allowed.
 Got an error uploading:
  • The file powernet426.mib does not have a valid extension for an attachment and has been removed. jpg,gif,png,xlsx,tar,rtf,csv,ppt,pptx,mov,mp4,qt,wmv,doc,docx,pdf,jpeg,txt,xls,arf are the valid extensions.
Thanks.
SupportIW
I'm having the same issue on Prime 3.4. Were you able to find a solution?
Kind Regards,
Richard Amersfoort
No I didn't.  We're just going to purchase APC StruxureWare Data Center Expert.
Thanks for your reply!
That`s unfortunate though... I'll try to ask TAC and otherwise we'll also look for a different solution.
I had the same issue (with another MIB), but I managed to fix it. Hopefully it can help someone else.
MIBs have dependencies, for example if you want to install CISCO-VOICE-DIAL-CONTROL-MIB you have to load in order the first 19 MIBs: Cisco MIBs
