9300 Network Module Compatibility
TW80CJ5
Level 6
Level 6
Good Morning!
I have a question regarding the Network Modules for Cisco 9300's. Are they compatible with different speed modules? For example:
User Switch has (2) NM-2Y (25 gig transmission per port)
Core Node Switch has (2) NM-8X (10 gig transmission per port)
Can I connect my User Switch to the Core Node? I realize it might reduce my throughput from User to Core Node, but I can port-channel the connections to make up for the downgrade in throughput speeds.
Thoughts / Suggestions?
Mark Elsen
 - Standard  networking architectures will usually include  the reverse where core has higher speed up links (capable of) then client switches. In your case  you can only connect , if core and client can negotiate  upon a common speed (per port).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Agreed on the Coren having high speeds...
However, I am wondering if the core and user switches can negotiate if the core is 10 Gig and User is 25gig ...???
we need to ask 1 question here, Do we really need user 25G connecting ? are the end-user ready for 25Gig connection.(it all depends on the requirement,) if the end-user required 25G connection you need to uplift all the uplink to 100G + network to make network path easy.
is this cost effective ( really not at all)?
BB
