Feature template is in grey
talmadari
Hey,
While trying to configure a new template (in this case NTP template) i'm not able to change template settings and getting the fields in grey (see image attached). does anyone knows why?
Also if i already have an NTP server configured on my devices, how do i replace them with new ones?
Tal
AFROJ AHMAD
H Tal,
The procedure for applying configs to devices in PIis to create, publish, deploy templates.
First navigate to Design -> Feature Design.  There exists some 'canned'
templates, but for most configurations you wish to apply to a device running NTP you would
simply use the CLI template.  Expand CLI Templates -> Click 'CLI' -> give it a name
and enter the commands to wish to apply (you don't need to enter config t) -> Save as
New Template
-> There is now a button named 'Publish', click it -> Deploy ->
select the appropriate devices.
Thanks-
Afroz
[Do rate the useful post]
***Ratings Encourages Contributors***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
Thanks for your quick replay, i know how to configure NTP using CLI template but on my devices i already have NTP server configured (each is using different IP) and i was looking for a way to configure on all devices (more then 500) a new NTP server while removing the old ones.
I hoped to achive this goal using the feature template but as i mentioned it's marked in grey so i can't type any values in it!?
Cheers,
Tal
Hi Tal,
Removing the existing and adding New NTP server info to the device can be achived via feature called compliance check .
unfortunately this is not yet supported in 2.0 . however it planned for the coming PI release.
Thanks-
Afroz
***Rating Encourages the Contributors***
