NEXUS TACACS AAA SOS PLS
KAROLY KOHEGYI
Level 2
Level 2
i miss the aaa and tacacs command order.
Now i can access the nexus but i am not able to config.
C2-BAL-NEXUS# sho run | i tacacs
feature tacacs+
aaa group server tacacs+ ACS
tacacs-server directed-request
C2-BAL-NEXUS# sho run | i aaa
snmp-server enable traps aaa server-state-change
aaa authentication login default group ACS
aaa authentication login console group ACS
aaa authorization config-commands default group ACS
aaa authentication login error-enable
the error messages!
Error: AAA authorization failed AAA_AUTHOR_STATUS_METHOD=17(0x11)
The reboot is very hard.
Any idea!!
Thank in advance!!
12 Replies 12
KAROLY KOHEGYI
Level 2
Level 2
NEXUS 7010 SUP1 5.2.7
I have solved the problem!
Was it because you had no "tacacs-server key" entry?
Yes!
The tacacs -server key and AAA server group were missing.
I found a little security hole ( or feature ) which  permits the config in this case.
can u guide us
how you solved
sumani1984
I have same issue
pls guide what changes u done
by
subramani
subramanian.ntwengr@gmail.com
sumani1984
same issue for me
can u guide
AAA failed
but local username
sh run
The most important that copy xxx.txt startup/runnning is working in this case as well.
This command merges the startup config and the commands in xxx .txt without authorization.
I think the command uses the shell privilige level w/o AAA.
You may  lose nothing if you try it.
br
can u pls guide me in
acs 5.4
for above said changes
we configured this at nexus 7010  & failed
nexus 7010:
tacacs-server key 7 "admin123"
tacacs-server host *.*.*.*
aaa group server tacacs+ tacacs+
    server *.*.*.*
    server *.*.*.*
    deadtime 10
    source-interface Vlan**
aaa authentication login default group tacacs+
aaa authentication login console group tacacs+
aaa authorization config-commands default group tacacs+
aaa authorization commands default group tacacs+
aaa authorization config-commands console group tacacs+
aaa authorization commands console group tacacs+
aaa accounting default group tacacs+
It seems to be good. Please check the AAA key.
key mismatch
we have configured in Nexus tac key with cote "****"
but acs 5.4 not able to add with cote as "****"
