08-11-2014 12:31 PM
In my net lan i have a tp-link media converter and not have link with a fiber port Cisco SG500-52P 52-port Gigabit POE Stackable Managed Switch
why not support?
08-11-2014 03:11 PM
Are you using a 1 Gbps SFP in port S1 or S2 on the switch? If so, what model of transceiver is it?
What model (part number) of media converter are you using? You would typically need something like the MC200CM for this application.
08-13-2014 02:18 PM
sfp Axcen (sfp-1000LX-DD-IT)
tp-link MC110CS
THANKS
08-13-2014 03:35 PM
08-15-2014 07:02 AM
MC110CS state auto negotiation and the AXCEN is 1 Gbps
04-06-2015 01:38 PM
i would change operate mode in my mc110cs
thanks
08-18-2014 02:17 PM
another tip ?
thanks
