Filter Syslog on Router
Alvaro Garcia
I am looking for a way to filter syslog on a router to only forward the below message to a syslog server:
%SYS-5-CONFIG_I: Configured from console by console
I dont want to see any of the other logs on the syslog server.
Thanks for you help.
That's great!
It is something I've never had the chance to check.
Giorgos
6 Replies 6
garapoglou
Level 3
Level 3
I don't think that changing the logging level could isolate and log configuration changes only. So in my opinion you need to create a standard ACL which permits telnet connections and logs them.
It should be something like this:
access-list 1 permit (ip address) log
Then you should add the access-class to the VTY lines:
line vty 0 4
access-class 1 in
Everytime someone telnets the device the event will be logged.
Best regards,
Giorgos
Thanks for the suggestion.... but Im not sure if that is what we are trying to accomplish...
Doing some reasearch I fiund the logging descrimatro feature:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htnmsylg.html#wp1056364
I am not quite familiar with thata feature so I am wondering if that would helo me achieve what I need... I know you use it to "drop" syslog messages but I am not sure if you use it an access list to just permit 1 specific syslog and do a kind of "deny any any"....
You are welcome!
Well, according to the document, I don't think you need to create an ACL.
Since you create a descriminator, only logs that match it will be sent. So you don't need to block anything.
I think you should give it a try.
Best regards,
Giorgos
Alvaro Garcia
I was able to do it using the logging discriminator feature... I used the following line:
logging discriminator Config facility includes SYS mnemonics includes CONFIG_I
Then you only need to apply the discriminator to the syslog session and voilà.....
That's great!
Giorgos
Thx for the info!
I wanted to filter out interface up/down messages sent to our Cisco Prime syslog and used the following commands to make it happen.
logging discriminator linkud mnemonics drops UPDOWN
logging host "IP of syslogserver" discriminator linkud
