Final Skills
Skyamoebe551
Hello I am working on a final skills for my college class. I am a little lost when it comes to the instructions. If I could get any little help I would greatly appreciate the help. I have attached the Packet Tracer too. I could really use the help.
Spanning Tree mode: Rapid Spanning Tree
Trunks:
1. All links between DLS2 & ALS1-2 and DLS3 & ALS1-2
2. DLS2 & ALS1 – Ports Fa0/3-4
3. DLS2 & ALS2 – Ports Fa0/7-8
4. DLS3 & ALS1 - Ports Fa0/7-8
5. DLS3 & ALS2 – Ports Fa0/1-2
Etherchannels:
1. Create L2 Etherchannels between DLS2 & ALS1-2 and DLS3 & ALS1-2
2. Set mode to On
3. DLS2 –> ALS1 = Portchannel 4
4. DLS3 –> ALS1 = Portchannel 6
5. DLS2 –> ALS2 = Portchannel 6
6. DLS3 –> ALS2 = Portchannel 4
1. Create L3 Etherchannels between DLS1-3
2. Set mode to On
3. DLS1-2 = Portchannel 2 -> DLS1 = 211.228.2.1/24 DLS2 – 211.228.2.2/24
4. DLS1-3 = Portchannel 3 -> DLS1 = 211.228.3.1/24 DLS3 – 211.228.3.3/24
5. DLS2-3 = Portchannel 1 -> DLS2 = 211.228.1.2/24 DLS3 – 211.228.1.3/24
VLANs:
VLAN# VLAN Name Assign to Ports
228 (native) NetMan 9 – 10 on ALS1-2!
10 UpMan 11 – 12 on ALS1 & ALS2!
15 R&D 13 – 16 on ALS1 & ALS2!
20 MidMan 17 – 20 on ALS1 & ALS2!
30 LowMan 21 – 24 on ALS1 & ALS2!
STP:
1. DLS2 is the Root Bridge for VLANs 10, 15, and 228.
2. DLS2 is the Secondary Bridge for VLANs 20 and 30.
3. DLS3 is the Root Bridge for VLANs 20 and 30.
4. DLS3 is the Secondary Bridge for VLANs 10, 15, and 228
VTP:
1. DLS2-3 = Server
2. ALS1-2 = Client
3. VTP password = ciscoccna2022
4. VTP Domain = lcmcis228.com
5. VTP Version = 2
IP Addressing Scheme: Feel free to use a scheme that you are comfortable with. You should
utilize VLSM /30 between the layer 3 devices.
Be sure to implement topics covered in CIS 140 & CIS 226 where appropriate. Implement
the routing protocol of your choice, RIP, EIGRP, or OSPF.
DHCP:
1. Configure DHCP on DLS2
2. Configure DHCP for VLANs 10, 15, 20, 30 and 228
3. Exclude the first 25 IP Addresses from each Network
4. Exclude the last 10 IP Addresses from each Network
5. Configure the pool name to be: <VLAN#>Net
6. Configure the default router address = 211.228.x.254/24, where x = VLAN#
InterVLAN Routing:
1. Network Addresses = 211.228.x.0/24, where x = VLAN# or L3 Portchannel#
2. Network Address on EdgeRtr to DLS1 = 211.228.4.2/24
3. Network Address on DLS1 to EdgeRtr = 211.228.4.1/24
4. SVI/Default Gateway Address is always 211.228.x.1/24 on DLS2
5. SVI/Default Gateway Address is always 211.228.x.3/24 on DLS3
6. Configure the router id to be 255.255.255.255 on EdgeRtr.
7. Configure the router id of DLS1-3 to be x.x.x.x, where x is 1, 2, or 3.
8. Configure the networks connecting DLS1-3 and EdgeRtr to be in OSPF Area 0.
9. Configure each VLAN to be in OSPF Area 0.
10. Configure a default route using EdgeRtr’s Gi0/0 interface as the exit interface.
11. Propagate the default route throughout OSPF.
12. Configure DLS2 to be the DR for VLANs 10, 15, and 228.
13. Configure DLS3 to be the DR for VLANs 20 and 30.
Network Management:
1. DLS2 NetMan VLAN IP Address = 211.228.228.1/24
2. DLS3 NetMan VLAN IP Address = 211.228.228.2/24
3. ALS1 NetMan VLAN IP Address = 211.228.228.3/24
4. ALS2 NetMan VLAN IP Address = 211.228.228.4/24
HSRP:
1. Configure DLS2 as the Active HSRP Router for VLANs 10, 15, and 228.
2. Configure DLS2 as the Standby HSRP Router for VLANs 20 and30.
3. Configure DLS3 as the Active HSRP Router for VLANs 20 and30.
4. Configure DLS3 as the Backup HSRP Router for VLANs 10, 15, and 228.
5. Configure 211.228.x.254/24 as the Virtual HSRP IP Address, where x = VLAN#
6. Configure Preemption.
Security:
1. Shutdown and place into VLAN 51 named Area51 all unused ports
2. Configure an ip host command for each Device on every Device
3. Configure SSH on every Switch
a. Username = Manager, Privilege Level = 15, Password = ciscoccna2022
b. Modulus = 2048
c. Version = 2
d. Domain name = ccna3.lmc.edu
4. Enable Secret = ciscoccna2022
5. Console password = ciscoccna2022con
6. Turn off DNS
7. Turn off CDP when completed
8. Secure layer 2 switched ports, and shutdown unused ports.
9. Use ACLs to restrict SSH to all devices to only a single host
I have completed the lab. Attached the revised file. I suggest to go over each line in the instructions, try to understand what part of the configuration corresponds to each line, and why it is configured the way it is.
24 Replies 24
what you want? ask specific question here to help with.
Good luck
KB
All the instructions that I am to follow is everything after the spanning tree title. The packet tracer is also included but I am looking for configuring tips for how to set up each section.
How do I set up the Etherchannels:
2. Set mode to On
2. Set mode to On
--> DLS2 –> ALS1 = Portchannel 4
ALS1
interface Port-channel4
switchport mode trunk
interface FastEthernet0/1
channel-group 4 mode on
interface FastEthernet0/2
DLS2
Would I follow this same configuration for  the rest of these?
And here is the layer 3 port channel config:
DLS1
interface Port-channel2
no switchport
ip address 211.228.2.1 255.255.255.0
no switchport
no ip address
channel-group 2 mode on
duplex auto
speed auto
no switchport
no ip address
duplex auto
speed auto
DLS2
no switchport
ip address 211.228.2.2 255.255.255.0
interface FastEthernet0/3
no switchport
no ip address
duplex auto
speed auto
interface FastEthernet0/4
no switchport
no ip address
duplex auto
speed auto
Revised file attached...
Would I follow this configuration for the others too?
indeed, the configuration would be the same (with different port channel numbers and IP addresses obviously).
Thank you! For assigning VLANs names would this be the configuration lines? I have attached the instructions for what I need.
Configuration: interface vlan 228
name NetMan
switchport access vlan 228
VLANs instructions
I think what they are looking for is this:
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#vlan 10
Switch(config-vlan)#name UpMan
Switch(config-vlan)#end
I think I have the Vlans all set. I am not sure how to configure the STP section. I could use a little help with that.
this is how to configure the root:
DLS2(config)#spanning-tree vlan 10,15,228 root primary
DLS2(config)#spanning-tree vlan 20,30 root secondary
For the VTP- I am trying my best!!
VTP:
1. DLS2-3 = Server
2. ALS1-2 = Client
5. VTP Version = 2
is this the configuration: vtp mode server or client
vtp password
vtp domain
vtp version 2?
I am now stuck on the IP Addressing Scheme and how to implement RIP, EIGRP or OSPF. How would I get that started and where would I need it applied too?
