Fixing Prime LMS 4.2 Best Practices Deviations
davemiddlewick
Quick question:-
Is there a way of running a fix for a large number of devices in one go or do I have to fix one line at a time?
I need to fix around 400 devices to turn CDP off on access ports.
AFROJ AHMAD
Hi Dave,
Use the Netconfig Option: create a Job for all 400 devices and you should be good.
check the below link:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps11200/deployment_guide_c07-683965.html#wp9001098
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks Afroz
Don't think NetConfig will do it (unless I'm missing something), the configuration changes will differ depending on the device, so there will be a large number of different jobs.  Anybody got any other ideas?
I resist the "disable CDP on access ports" recommendations as I don't agree with it. For one, It's useful and necessary for any Cisco VOIP deployment. It also is useful to see if someone has plugged in a Cisco switch or plugged one port into another port (I have seen both) in which case it can be used in troubleshooting.
I even have taken to turning on LLDP - especially for customers with Avaya VOIP since Avaya phones announce themselves via LLDP (and it's pretty easy to make servers do so as well).
