Flexible Netflow configuration Vlan issues
John Nagy
Visitor
Ok so this is going to be kinda of a book on Netflow and some very useful items I also have some issues with the setup. So lets jump right in. I have a Cisco 9500 and it is used as our core user switch. it connects to our data coure switch which connects all of our server and the ASA that we have. On any give switch we have 20 or so vlans and so forth. THe task was to create a net flow configuration on the core switch that would allow both ingress and egress traffic to our collector in this case that collector is solar winds. Solarwinds and support both version 5 and version 9 in my case I'm using version 9. I have read just about everything that I can on the netflow configurations thus far. So for the 9500 in order for each layer 3 port to have ingress and egress you have to configure two of each thing. Two flow records an input and an output record. Then you have to configure two exporters. But there is a got ya on this one each of the exporters have to have different ports configured for them. In my case because I'm using solarwinds i'm using 2055 and 9995. Then you have to have two flow monitors an input and an output but there is another i got ya on this one each flow monitor has to be configured with both the udp ports that you have configured. Then you simply apply the configuration to you layer three ports. Ha you thought that was all so here are the issues. First you can apply the config to any physical interface that you want ie gi1/0/1 and so forth. You can apply it to a port channel. Oh you that that was easy no its not you have to apply to only a layer three port channel but there is a another got ya your port members have to be layer 2 and your port channel has to be layer three and you cant have both configured at the same time so in my case sat my port channel is port-channel100 and name is core uplink it has to have the command no switchport and it has to be configured with an ip address ie 192.168.0.1 255.255.255.0 once it is configured in this way then you can assign your config to the port channel group. I wont go into the solarwinds config part but there are a lot of back end changes that have to be made in order for this config to work see the working config below ip addresses have been changed to protect the innocent.
flow record RECORD-IN
match flow direction
match interface input
match ipv4 destination address
match ipv4 protocol
match ipv4 source address
match ipv4 tos
match transport destination-port
match transport source-port
collect counter bytes long
collect counter packets long
collect interface output
collect transport tcp flags
flow record RECORD_OUT
match interface output
match ipv4 protocol
match ipv4 tos
collect interface input
flow exporter Exporter_UDP_9995
destination 192.168.0.1
source Loopback0
transport udp 9995
flow exporter Exporter_UDP_2055
source Loopback0
transport udp 2055
flow monitor MONITOR_IN
cache timeout inactive 10
cache timeout active 60
record RECORD-IN
flow monitor MONITOR_OUT
record RECORD_OUT
This is a config from a live environment and everything works on this piece as expected data is flowing into and out of the ports and its getting reported back to the collerctor. Below is the clean config with out all the extra junk and things you do not need to know but wish you did.
version 17.3
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
service counters max age 10
service call-home
platform punt-keepalive disable-kernel-core
hostname Corp-9500-1
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 1000000
no logging console
logging cns-events notifications
aaa new-model
aaa authentication login local_auth local
aaa session-id common
clock timezone est -5 0
clock summer-time est recurring
switch 1 provision c9500-24y4c
switch 2 provision c9500-24y4c
boot system bootflash:packages.conf
stackwise-virtual
domain 1
ip multicast-routing
ip domain name notyours.net
login on-success log
vtp mode transparent
no device-tracking logging theft
match ipv4 protocol
match ipv4 tos
match ipv4 protocol
match ipv4 tos
source Loopback0
transport udp 9995
source Loopback0
transport udp 2055
record RECORD-IN
record RECORD_OUT
password encryption aes
license boot level network-advantage addon dna-advantage
diagnostic bootup level complete
spanning-tree mode rapid-pvst
spanning-tree backbonefast
memory free low-watermark processor 290409
redundancy
mode sso
transceiver type all
monitoring
vlan 2
name VoIP
vlan 3
name Data
vlan 60
name Printers
vlan 70
name Cameras
vlan 80
name Entrances
vlan 90
name Workstations
vlan 116
name Maint_Ext
vlan 117
name Vorne
vlan 118
name Scalehead
vlan 120
name Maint_NUB
vlan 130
name Power
vlan 160
name Clocks
vlan 190
name Vending
vlan 191
name HVAC
vlan 192
name Credit_Card
vlan 700
name Mgmt_VLAN
vlan 703
name AP+PTP
interface Loopback0
no ip address
interface Port-channel1
description Uplink to MDF
switchport mode trunk
interface Port-channel2
description Uplink to IT-UPS
interface Port-channel3
description Uplink to Giftshop
interface Port-channel12
description Uplink to Datacore
no switchport
ip flow monitor MONITOR_IN input
ip flow monitor MONITOR_OUT output
ip address x.x.x.x 255.255.255.252
ip pim dense-mode
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface TwentyFiveGigE1/0/1
channel-group 1 mode on
interface TwentyFiveGigE1/0/2
channel-group 2 mode on
interface TwentyFiveGigE1/0/3
channel-group 3 mode on
interface TwentyFiveGigE1/0/12
no switchport
no ip address
channel-group 12 mode on
interface TwentyFiveGigE1/0/24
stackwise-virtual dual-active-detection
description DAD link
interface HundredGigE1/0/25
interface HundredGigE1/0/26
interface HundredGigE1/0/27
stackwise-virtual link 1
description Stacking Cable 1
interface HundredGigE1/0/28
description Stacking Cable 2
interface TwentyFiveGigE2/0/1
interface TwentyFiveGigE2/0/2
interface TwentyFiveGigE2/0/3
interface TwentyFiveGigE2/0/12
no switchport
no ip address
interface TwentyFiveGigE2/0/24
interface HundredGigE2/0/25
interface HundredGigE2/0/26
interface HundredGigE2/0/27
interface HundredGigE2/0/28
interface Vlan1
no ip address
shutdown
interface Vlan2
description VoIP
ip address 192.50.123.2 255.255.248.0
no ip redirects
no ip unreachables
ip pim dense-mode
ntp broadcast
interface Vlan3
description Data VLAN
ip address 192.50.123.5 255.255.0.0 secondary
ip address 192.50.123.7 255.255.0.0
ip helper-address 192.50.123.9
ip helper-address 192.50.123.11
no ip redirects
no ip unreachables
interface Vlan60
description Printers
ip address 192.50.123.13 255.255.0.0
ip helper-address 192.50.123.15
no ip redirects
no ip unreachables
interface Vlan70
description Cameras
ip address 192.50.123.17 255.255.0.0
no ip redirects
no ip unreachables
interface Vlan80
description Entrances
ip address 192.50.123.19 255.255.0.0
ip helper-address 192.50.123.21
no ip redirects
no ip unreachables
interface Vlan90
description Workstations
ip address 192.50.123.23 255.255.0.0
ip helper-address 192.50.123.25
no ip redirects
no ip unreachables
interface Vlan116
description Maint_Ext
ip address 192.50.123.27 255.255.0.0 secondary
ip address 192.50.123.229 255.255.0.0
interface Vlan117
description Vorne
ip address 192.50.123.31 255.255.0.0
ip helper-address 192.50.123.33
interface Vlan118
description Scalehead VLAN
ip address 192.50.123.35 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan120
description Vlan 120
ip address 192.50.123.37 255.255.0.0 secondary
ip address 192.50.123.41 255.255.0.0
interface Vlan130
description Power
ip address 192.50.123.43 255.255.0.0
no ip redirects
no ip unreachables
interface Vlan160
description Clocks
ip address 192.50.123.45 255.255.0.0
ip helper-address 192.50.123.47
no ip redirects
no ip unreachables
interface Vlan190
description Vending
ip address 192.50.123.49 255.255.255.0
ip helper-address 192.50.123.51
no ip redirects
no ip unreachables
interface Vlan191
description HVAC
ip address 192.50.123.53 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan192
description Credit Card Machine
ip address 192.50.123.55 255.255.255.0
ip helper-address 192.50.123.57
no ip redirects
no ip unreachables
interface Vlan700
description Mgmt VLAN
ip address 192.50.123.59 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan703
description AP+PTP
ip address 192.50.123.61 255.255.255.0
ip helper-address 192.50.123.63
no ip redirects
no ip unreachables
router ospf 1
network x.x.x.x 0.0.255.255 area 0
network x.x.x.x 0.0.7.255 area 0
network x.x.x.x 0.0.0.255 area 0
network x.x.x.x 0.0.0.3 area 0
ip default-gateway x.x.x.x
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http secure-trustpoint TP-self-signed-2970070898
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip ssh source-interface Vlan700
ip ssh version 2
Alright there it is all nice and neat and cut and dried. So as I have said everything is working and sending traffic. What I cant get working is the Vlan's none of them are sending their data to the collector. Is that because the ports that are switched to the vlan already have the netflow config or is there additional Information that is needed in order to get them to start sending their data.
Georg Pauwen
I'll check your config, the one thing I did notice right away was the presence of this command:
--> ip default-gateway x.x.x.x
This is needed on layer 2 devices only, so you want to remove that line.
Georg Pauwen
I seem to recall that Flexible Netflow is not supported at all on SVIs on the 9500. Bridged Netflow is an option:
--> The device does not support tunnels and SVI interfaces; however Layer 2 and Layer 3 physical interfaces and VLAN configuration mode are supported.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-8/configuration_guide/nmgmt/b_168_nmgmt_9500_cg/b_168_nmgmt_9500_cg_chapter_0111.html#task_A53900A8C0F743EFB85D77C4D666E091
So the question on that is do I have to configure that for each of the vlans or does that config work on all the vlan's
example
config t
vlan configuration 2
Does that work for all the vlan's or do I have to apply configuration as
vlan configuration 3
vlan configuration 90
and then it will send the netflow traffic
And as far as the ip default gateway for my environment that line is required but thank you for the insight on that one line.
good question...I honestly have no idea. Does it work for one Vlan when you put this under the configuration for that one Vlan ?
The 'ip default-gateway' is only needed if your switch is a layer 2 only switch. Judging from your config, it is not (you are running OSPF, multiple SVIs, etc.). The line can cause unexpected problems with routing, so I suggest to remove it.
