Unable to add C9300 Series Switches in CNA 6.3(4)
Hello Team,
I'm unable to add C9300 Series Switches in Cisco Network Assistant Version 6.3(4)
kindly help me out on this issue.
Thanks in advance!!
Best regards
Devender Budhiraja
marce1000
 - Cisco CNA is old and no longer supported by Cisco , it does not support that type of modern switches neither.
 M.
Thanks for the information!!
Is there any substitute available for CNA 6.3(4) ?
Kindly confirm back.
Thanks & regards,
Devender Budhiraja
                                    >...Is there any substitute available for CNA 6.3(4) ?
  - FYI : https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/datasheet-c78-735696.html  and https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/dna-center/nb-06-dna-center-data-sheet-cte-en.html
 M.
as @marce1000 said, the newer Catalyst switches are not supported in Cisco Network Assistant. The main issue with any replacement is: CNA is free, while (most all of) the feasible alternatives cost money. Prime and DNAC are expensive. How many of these devices do you have ?
