Flexible NetFlow through Cryptomap Tunnel
linker.team
Hi Guys,
Came to know that FNF will solve the issue of exporting NetFlow packets through Cryptomap Tunnel.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/ps6965/prod_white_paper0900aecd804be1cc.html
Confiugred my router to export Flexible NetFlow through Cryptomap tunnel. But I am not seeing any NetFlow packets on my management server. Verified this using packet capture tool (Wireshark). I have attached my configuration. Any help will be deeply appreciated.
jakewilson
If the traffic is encrypted in a tunnel, some NetFlow Analyzers like Scrutinizer will drop data such as:
  • ENCAP(98)
  • ESP(50)
  • ETHERIP(97)
  • GRE(47)
  • IPIP(94)
This done because some routers will export the same data twice (i.e. once in native format, a second time as tunneled traffic).  This causes excessive utilization reports that are not accurate.
This dropping of traffic was recommened by Cisco.  I hope I understood your question.
Jake
I think you have not understood my question. I have mentioned that NetFlow packets are not reaching the server, thats why I have mentioned that wireshark also does not packets on the server.
sorry about that.  Any chance something in the path could be filtering the traffic?  I haven't set up a Cryptomap Tunnel before.
