Free Cisco Network Management Tool
Jagsuvce G
I need to Monitor Link Utilization and at the same time Router & Switch CPU Memory Utilization & Interface (CRC Errors, Broadcast etc ).
Is there any free cisco network management tool for the same. I do have CCO login for downloading.
Is there any such tool pls let me know.
7 Replies 7
rsgamage1
Level 3
Level 3
You can use SNMP traps and an nms server of your choice for this purpose.
I am looking for some cisco tool, if any pls let me know.
MRTG
We have some free NMS tools, but most won't give you the level of detail you are looking for for free.
Most of the freeware tools like CCA and CNA are for configurations, but not the monitoring like you are looking for.
Have a look at Cisco Network Assistant. It is designed for a maximum of 40 devices.
http://www.cisco.com/en/US/products/ps5931/index.html
Thanks for your suggestion.
Let me go for some paid tool.
Best option is OpenNMS. it is free, runs on Linux
