frequent alert from lms 3.1
nizamismail
Hi all,
I keep getting this email alert from LMS 3.1:
ALERT ID = 00000S1
TIME = Thu 20-Aug-2009 16:08:17 SGT
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 10.110.1.3
MANAGED OBJECT TYPE = Routers
EVENT DESCRIPTION = 10.110.1.3: Authentication Failure:MinorAlarm; 10.110.142.2 [10.110.1.3]:Unresponsive; 10.110.2.10 [10.110.1.3]:Unresponsive; 10.110.2.6 [10.110.1.3]:Unresponsive;
CUSTOMER IDENTIFICATION = Tech Support
What does the alert mean?
Joe Clarke
It means a few things. One, this particular device is being polled with the wrong SNMP credentials by some management station. Additionally, IPs 10.110.142.2, 10.110.2.10, and 10.110.2.6 are not ICMP-reachable from DFM.
The first event can be fixed by finding the management station doing the polling, and either stopping it, or correcting the SNMP credentials. As for the others, if DFM is really unable to ping those other IPs, then simply unmanage them under DFM > Device Management > Device Details.
