Showing results forĀ
Search instead forĀ
Did you mean:Ā
FT CONFIGURATION ISSUE ON ACE 4710
sashimoy11
Dear All,
I have configured ft on ace 4710 for failover, but the failover is not working. Each ace is acting as active, whereas the peer  status is showing " FSM_PEER_STATE_DOWN".
I am ataching the configuartion file of both ace.
Note: Physically I have configure both ace device separately, but my confusion is do I need to configure only on primary ace and the same will be replicate on secondary ace automatically (like failover in ASA configuration) or it is ok.
Sashi
sashimoy11
Dear all,
Pls help me out in this regard, I dont have much idea about ACE.
Sashi
