ftp not working on Prime NCS
Gerald King
OK, I have a customer whom we are migrating from WCS to Prime Infrastructure 1.3. As I understand it, I need NCS in the middle to migrate from WCS >> NCS >> PI1.3.
I have Prime NCS running, I followed instructions:
http://www.cisco.com/en/US/partner/docs/wireless/ncs/1.1/release/notes/NCS_RN1.1.1.html#wp298425
http://www.cisco.com/en/US/docs/wireless/ncs/1.1/configuration/guide/tasks.html#wp1215225
When I try and connect to the NCS server via ftp using Filezilla or WS-FTP with username/ftp-user & password/ftp-user I get the following:
Status:          Connecting to 10.160.17.89:21...
Status:          Connection attempt failed with "ECONNREFUSED - Connection refused by server".
Error:          Could not connect to server
Status:          Waiting to retry...
Status:          Delaying connection for 1 second due to previously failed connection attempt...
Status:          Connecting to 10.160.17.89...
Response:          fzSftp started
Command:          open "ftp-user@10.160.17.89" 22
Command:          Pass: ********
Error:          Authentication failed.
Error:          Critical error
Command:          open "ftpuser@10.160.17.89" 22
Status:          Connection established, waiting for welcome message...
Response:          220 Service ready for new user
Command:          USER ftpuser
Response:          331 User name okay, need password for ftpuser
Command:          PASS ********
Response:          530 Access denied
Command:          USER ftp-user
Response:          331 User name okay, need password for ftp-user
Error:          Connection timed out
What might i be doing wrong?
Thanks in advance for your help.
Rob Johnson
are you able to ssh or console into the NCS appliance?
if so, please run an ncs status command to see if all ncs processes are running:::
also, can you try to launch an MS-DOS or CMD prompt and try to
ftp xxx.xxx.xxx.xxx
enter ftp-user for the username
enter whatever password you think it is.
