Gets SNMP errors Interface
Natha340Mai340
Level 3
Level 3
Hello, I wanted get erros for an interface by gets snmps from a external software. for exemplo, from Linux machine I'm able type
snmpwalk -c public -v 1 ip_of_my_switch
so it's return all OID avaliable for that device. what I wish is find out what is OID wich return me interfaces errors.
someone know what is OID for Interfaces errros from switches Cisco or how can I gets that OID ?
any tip is welcome
thanks
Natha340Mai340
Level 3
Level 3
Hi,  I have solved my issue through Getif program. I get the OIDs and I used the snmpwalk from linux.
for exemplo,
snmpwalk -v 1 -c public 192.168.215.1 .1.3.6.1.2.1.6.13.1.1
the OID .1.3.6.1.2.1.6.13.1.1 I got through Getif program.
thanks.
