GLBP Failover not working - Reachability is Down (no route)
vishwasjaiswal
Hi Guys,
I am having 2 internet routers connected with two different ISPs.
i am running GLBP between the 2 routers.
Whenever any one of the internet links goes down the auto failover does not work.
I have to manually shut the LAN interface of the router to divert the traffic.
below is the config of the router.
Please help me to check if i am missing somthing in config.
I have used the below config to track the WAN interface
track 1 ip route 220.227.202.150 255.255.255.255 reachability
When I do sh track i got the below output & I doubt if that is the problem
Track 1
  IP route 220.227.202.150 255.255.255.255 reachability
  Reachability is Down (no route) ============================> Reachability show down
    1 change, last change 3w0d
  First-hop interface is unknown ==============================>
  Tracked by:
    GLBP GigabitEthernet0/0 1
sh ip bgp sum
Neighbor        V          AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
199.63.142.12   4        125   29559   29592       39    0    0 16:28:47        2
220.224.145.8   4      18101   63727   58186       39    0    0 6d10h           1
IE1A-Rel-Int#
Interface config
interface GigabitEthernet0/0
ip address 199.63.142.11 255.255.255.0
ip access-group 102 in
ip flow ingress
duplex full
speed auto
glbp 1 ip 199.63.142.10
glbp 1 weighting 110 lower 95 upper 105
glbp 1 weighting track 1 decrement 20
end
interface GigabitEthernet0/1
description *** Reliance 120M 5000000000056 Ckt ID ****
ip address 220.227.202.149 255.255.255.252
ip access-group 103 in
ip flow ingress
duplex full
speed 1000
end
ip route 220.224.145.8 255.255.255.255 220.227.202.150 ======> One static route
IE1A-Rel-Int#sh ip ro 220.227.202.150
Routing entry for 220.227.202.148/30
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via GigabitEthernet0/1
      Route metric is 0, traffic share count is 1
Additional info
sh glbp b
Interface   Grp  Fwd Pri State    Address         Active router   Standby router
Gi0/0       1    -   100 Standby  199.63.142.10   199.63.142.12   local
Gi0/0       1    1   -   Active   0007.b400.0101  local           -
Gi0/0       1    2   -   Listen   0007.b400.0102  199.63.142.12   -
IE1A-Rel-Int#
sh glbp
GigabitEthernet0/0 - Group 1
  State is Standby
    39 state changes, last state change 16:19:19
  Virtual IP address is 199.63.142.10
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.576 secs
  Redirect time 600 sec, forwarder timeout 14400 sec
  Preemption disabled
  Active is 199.63.142.12, priority 100 (expires in 8.576 sec)
  Standby is local
  Priority 100 (default)
  Weighting 90, low (configured 110), thresholds: lower 95, upper 105
    Track object 1 state Down decrement 20
  Load balancing: round-robin
  Group members:
    0027.0d93.b4c0 (199.63.142.11) local
    0027.0d93.bae0 (199.63.142.12)
  There are 2 forwarders (1 active)
  Forwarder 1
    State is Active
      15 state changes, last state change 6d08h
    MAC address is 0007.b400.0101 (default)
    Owner ID is 0027.0d93.b4c0
    Preemption enabled, min delay 30 sec
    Active is local, weighting 90
    Client selection count: 8
  Forwarder 2
    State is Listen
      16 state changes, last state change 16:19:29
    MAC address is 0007.b400.0102 (learnt)
    Owner ID is 0027.0d93.bae0
    Time to live: 14397.728 sec (maximum 14400 sec)
    Active is 199.63.142.12 (primary), weighting 90, low (expires in 8.640 sec)
IE1A-Rel-Int#
I have also attached the config of the both the routers.
Please help me in getting this fix. I am not sure if I am missing somthing in config.
Thanks in Advance !!!!
0 Replies 0
