Grafana | InfluxDB | Telegraf
velo84
I have Telegraf setup and monitoring interfaces on Cisco routers correctly. Is it possible to monitor IP SLA instances with this same setup? If anybody has had any luck with this I would be grateful if you could share the setup.
balaji.bandi
I can not remember i tried for one client, send the IP SLA information with TAG  send to Elastic Search..need to dig the information my documents.,
is this what you looking?
BB
If you have any info then that would be great if you could send it over. It might point me in the right direction.
Very problably.
My goal, in terms of final results, is something like that 
I will eagerly await your information about this
