hang device logging.
_Ratha_
Level 3
Level 3
How can I show log or get log file from Cisco Switch during hanging?
Ratha.
Deepak Kumar
I advise for configure SYS LOG server and send all debug level logs on the server But I never advised for run any debug commands such as "Debug IP Packet" or another. It will kill switch memory and CPU.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
ip_guy
Level 2
Level 2
Hello Ratha,
You can use for e.g. debug ip icmp detail and debug ip packet detail, so you will get input in real time. You can enable terminal monitor (term mon command) if you are connected via vty which replicates like logging to the console.
Also, you can setup Span Session and capture the traffic on either side in Wire-shark.
Have in mind that syslog server is by default enabled in Cisco routers/switches, you just need to forward to the desired server (Linux, MS Server, etc.)
I hope that I gave you answers that you were looking for.
Cheers
Deepak Kumar
Deepak Kumar
Deepak Kumar,
