Having trouble accessing WLC after initial configuration. (Cisco Packet Tracer)
Networking_Adz
Hello there everyone, So I am having an issue with this network I created. Its a router on a stick configuration that I have been asked to create. The main issue I am having with this network is that I am trying to configure my WLC1 through the web browser. The problem is when I try to configure this WLC with a Management VLAN ID (88). When I finish the configuration after creating an admin user, where the WLC1 would reboot, I can no longer access it. Pinging does not work either for some reason. I have tried both in HTTPS and HTTP but no luck. If anyone could point out the issue and hopefully fix the problem I would greatly appreciate it. Thanks
The 3 networks that are used in this configuration are for the following,
VLAN10: 172.16.10.0/24 (SSID: WminNet)
VLAN20: 172.16.20.0/24 (SSID: Staff)
VLAN88: 172.16.88.0/24 (Management)
Below is the diagram that I have used in this case as you can see. (Also I have added a packet tracer attachment below).
Configurations for each device is the following,
Router 1
hostname R1
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.0
interface FastEthernet0/0.88
encapsulation dot1Q 88
ip address 172.16.88.1 255.255.255.0
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
snmp-server community R1RO RO
snmp-server community R1RW RW
logging 10.0.1.11
line con 0
line aux 0
line vty 0 4
login
end
MLS1
hostname MLS1
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport trunk native vlan 88
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport trunk native vlan 10
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
WLC1 configuration
Management
IPV4 Address ------------------>172.16.88.254
Subnet Mask -------------------> 255.255.255.0
Default Gateway -----------------> 172.16.88.1
SW1 configuration
hostname SW1
switchport access vlan 10
switchport mode access
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
SW2 Configuration
hostname SW2
switchport access vlan 88
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
AP1
DHCP Used
PC1
IPV4 ---- 172.16.10.10
Subnet Mask ----- 255.255.255.0
Default Gateway  ----- 172.16.10.1
DNS Server ------ 10.0.1.10
PC2
IPV4 ------ 172.16.88.10
Subnet Mask ------- 255.255.255.0
Default Gateway ----- 172.16.88.1
DNS Server ----- 10.0.1.10
Jorrie
Try to input the value "0" in the Management VLAN ID. If you hover or click the "?" on the right side a message will appear regarding detail to management VLAN ID.
Martin L
I think you need instructions or a a sample lab from net academy.  There are sample labs in PT under File> Open samples > WLC.
there should be a class about PT and/or wireless using PT on netacademy.
https://www.netacad.com/courses/networking
https://www.netacad.com/portal/resources/packet-tracer
Regards, ML
**Please Rate All Helpful Responses **
Jorrie
